hawk hps brake pads/rotora slotted rotors
Old Sep 4, 2006 | 12:33 PM
BurnMac42's Avatar
BurnMac42
Default hawk hps brake pads/rotora slotted rotors
Quick question, today i replaced my front/rear brakes and front rotors with the aformentioned parts howeer they differed slightly from what was on my car stock. The stock rotors had an extra bolt that screwed into the rotor itself but did not seem to do anything at all, the rotora's did not have this. Does anyone know what that was for? and Secondly the Hawk brake pads came with all 8 pads however only 4 (2 fronts and 2 rears) of the pads had the extra metal rentention loop (for lack of a better term). Are these necessary as well?? the car seems to run fine with the new equipment i just dont want to all of a sudden have a massive break failure or damage.....
Old Sep 4, 2006 | 01:01 PM
SpeedRcr's Avatar
SpeedRcr
That bolt is so that the rear tires can't be mounted on the front it serves no other function. Reuse your shims from your oem pads it will help them not squeel
Old Sep 4, 2006 | 03:48 PM
Kolia's Avatar
Kolia
The metal retention loop thing sounds like the spring that is meant to drag on the rotors when the pads wear down and squeal.
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
samansharif
Sep 25, 2015 12:31 PM
