Some Camber and Toe questions..
Old Sep 9, 2006 | 01:28 PM
willha418's Avatar
willha418
Default Some Camber and Toe questions..
I just lowered my Z on some Tanabe springs and Koni Shocks.
I was wondering if I needed any camber kit / toe bolts to get my
suspension back to factory specs? Or is the suspension from
factory adjustable for Camber and Toe?
If I do need the kit/bolts, do I need them for front and rears?
Thanks in advanced..
Old Sep 9, 2006 | 01:39 PM
Mike Wazowski's Avatar
Mike Wazowski
did you get an alignment yet? It would depend on the results of your alignment as to if you would need camber/toe arms/bolts.
Old Sep 9, 2006 | 02:05 PM
willha418's Avatar
willha418
Nope, didnt get the alignment yet. But just eyeballing it, I can tell the
rears need some adjusting. So I just wanna kill two birds with one stone
and install the items and align it if need be without aligning it and then
having to install stuff and realigning afterwards.
I just want the rears to have 0 toe and -1.5 camber.
Fronts probably same. Anyway to adjust fronts?
thanks
Old Sep 9, 2006 | 03:01 PM
Mike Wazowski
cant adjust shiat with the OEM front or rear arms. You will need to go aftermarket if you are to far out of spec.
Old Sep 9, 2006 | 06:27 PM
willha418's Avatar
willha418
ok thanks man!!!
Old Sep 10, 2006 | 07:23 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
for fronts you need adjustable a arms. If interested, we have the Cusco's in stock
for the rear, if you need it, the SPC camber kit will do the trick for you
Old Sep 19, 2006 | 02:13 PM
sfarrah's Avatar
sfarrah
If you need front arms the SPL arms are on introductory price right now and will adjust caster and camber.
Old Mar 10, 2007 | 04:12 PM
Kevins350z's Avatar
Kevins350z
is 2.3 and 2.1 degree camber bad? thats what i got on my rear after a mild drop.
Old Mar 10, 2007 | 06:44 PM
sfarrah's Avatar
sfarrah
It's not bad. I run around -2 in the rear but my setup is geared for track performance. A good street/track compromise would be between 1.5 and 2 i'd say.
Old Mar 11, 2007 | 04:39 AM
Z1 Performance
Former Sponsor
over 2 degrees is getting up there for street use - the real concern is what your toe ended up at with camber set that high. I'd try to dial it back to around 2 degrees and keep more tire on the road
Old Mar 11, 2007 | 02:40 PM
Kevins350z's Avatar
Kevins350z
the guy told me he already max out the camber. could that be possible? my toe are 0.08 and 0.12 btw..
HoBrahYouStink
Jun 24, 2016 10:58 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
