End Links?
Old Apr 26, 2008 | 06:11 PM
  #281
thinking's Avatar
thinking
Originally Posted by fireZ
all i can say is that i highly recommend NOT using SPL end links. i had the oems on, and was getting some mild noise from them for several months and decided to go with SPL. i've had them on for about two weeks, followed the instructions to eliminate pre load on the sway bar and today i go up a driveway and the bolt connecting the endlink to the right lower control arm snapped in half. i'm a little pissed off to say the least..
Please let us know how SPL handles this.
Old Apr 26, 2008 | 07:49 PM
  #282
fireZ's Avatar
fireZ
will do.
here's what the bolt looks like:
Old Apr 27, 2008 | 05:48 AM
  #283
SteveZ's Avatar
SteveZ
Sorry to hear that, and thanks for the warning. Another one like yours about SPL turned me off to buying them, I just rec'd the links from Z1, they're going in tonight. It's hard to believe people can sell the links like SPL and in several posts I've seen 3 weeks, 3 months, person who bought them is screwed.
Don't they put any warranty on their product?
Old Apr 27, 2008 | 06:38 AM
  #284
350ZMPH's Avatar
350ZMPH
very sorry to hear that...try this one...
http://z1auto.com/prodmore.asp?model...ng&prodid=2886
Old Sep 10, 2008 | 07:45 AM
  #285
sik350's Avatar
sik350
subscribing...
Old Sep 10, 2008 | 08:08 AM
  #286
WTX350Z's Avatar
WTX350Z
Yes they fix it...one of the guys who got a broken bolt was a friend...SPL fixed it w/o any argument...his was very possibly due to improper install (Nissan Dlr)...but SPL sent him new parts.
Old Mar 28, 2011 | 10:46 PM
  #287
mgrotel's Avatar
mgrotel
will do.
I have white line end links, and this same thing happened to me, twice! First time white line replaced the links, even though it was only the bolt that broke. Just the other day, another bolt broke, waiting to hear back from them. I will prob go with power grid after this happened again. I even adjusted the links to have zero preload with weight on the wheels. O well, I hope to have better luck with the power grid pieces
Old Mar 28, 2011 | 10:58 PM
  #288
mgrotel's Avatar
mgrotel
Forgot to add, both breaks looked identical to that one pictured. And also both happened when angling the car up a driveway with an angle to it so that I didn't scrape. So I feel safe saying we both had the same problem, whether it be defective bolts, or something else
Old Mar 28, 2011 | 11:08 PM
  #289
JasonZ-YA's Avatar
JasonZ-YA
^ closely closely inspect the pictures............
the bolt used is a spec'd machined "shoulder bolt"....google it..
They use bolts machined 1/2" diameter in order to use lower cost 1/2" rod ends then since the hole in the sway bar and translink is an m12 hole (ie, dimensionally smaller) they machine the threaded section to fit the sway bar........thus giving the end user a "special" bolt thats weaker and hard to replace...
Replacement option:
purchase M12x1.75-65mm long 10.9 grade zinc coated bolts, then use prevailing torque lock nuts, then wrap the shank section of the bolt with aluminum tape strip......at the very least its a good trackside replacement for those users with this problem..
-J
Old Mar 29, 2011 | 06:12 AM
  #290
mgrotel's Avatar
mgrotel
interesting, i will be going with powergrids now to see how they fare
Old Mar 29, 2011 | 07:27 AM
  #291
e30cabrio's Avatar
e30cabrio
I had Whiteline, they fell apart in under two months. Powergrids have been in about two months no issues.
Old Mar 29, 2011 | 01:45 PM
  #292
JasonZ-YA's Avatar
JasonZ-YA
I made my own....
These are my rears:
https://my350z.com/forum/8954019-post22.html
-J
Old Mar 29, 2011 | 02:36 PM
  #293
mgrotel's Avatar
mgrotel
^ what kind of angles do those support? im mainly looking for some that will support high angles, thats why i like the powergrids
Old Mar 30, 2011 | 09:57 AM
  #294
mysterymann's Avatar
mysterymann
I have the SPL Endlinks front and rear, the rears are perfect and stay tight and make no noise..
but the fronts always get loose, I used locktite to try and prevent that from happening but it keeps coming loose, does anyone know how I can stop it from coming loose?
Old Mar 30, 2011 | 06:59 PM
  #295
JasonZ-YA's Avatar
JasonZ-YA
Yes....do my replacement option i mention here....
Originally Posted by JasonZ-YA
Replacement option:
purchase M12x1.75-65mm long 10.9 grade zinc coated bolts, then use prevailing torque lock nuts, then wrap the shank section of the bolt with aluminum tape strip......at the very least its a good track side replacement for those users with this problem..
-J
the prevailing torque lock nuts, top lock nuts, stover nuts - those are all names used for them, they are simply "all metal lock nuts"
These shown in the first picture:
https://my350z.com/forum/8293580-post16.html
I know for sure they work, as i use them on my front endlinks shown here:
https://my350z.com/forum/8293643-post22.html
-J
Old Mar 30, 2011 | 07:28 PM
  #296
mysterymann
Alright sweet!
Did you buy the new bolts and nuts online or at a hardware store?
Thanks!
Old Mar 30, 2011 | 08:40 PM
  #297
JasonZ-YA's Avatar
JasonZ-YA
search for a local metric bolt supply store............
but you can order from:
metric and multi-standard in Irving, TX as well..
-J
hulkout
Apr 28, 2017 09:00 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
pr_350z
Oct 1, 2015 05:03 PM
Tochigi_236
Sep 27, 2015 03:40 PM
