shocks question
Old Oct 7, 2006 | 12:37 AM
chinaman_87's Avatar
chinaman_87
Default shocks question
this sounds stupid but could i use revised shocks for unrevised springs?
Old Oct 7, 2006 | 01:16 AM
JETPILOT's Avatar
JETPILOT
The spring rate must match the shock valving. They work in conjunction with each other. You're question is a little vague. Care to elaborate?
JET
Old Oct 7, 2006 | 06:18 AM
Gsedan35's Avatar
Gsedan35
Been their done that, answer is yes.
Differance is that your asking the rear shocks to dampen 20% less spring rate. Rear shocks do not get anywhere close to a overdampned in actual use with the softer unrevised rear springs.
A much bigger change will come from the fact that the revised shocks have a whole lot less compression dampning. But, they also have a whole lot better rebound control. You will be kiling off a lot of bounce and freeway porposing. I liked the unrevised shocks high compression dampning, but gave up living with the bounce and porposing a long time ago.
Old Oct 7, 2006 | 09:13 AM
chinaman_87
so it is a good setup to get unrevised springs with revised shocks from a 350z? or should i get both revised springs and shocks?
issyz
Jul 2, 2017 03:04 PM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
Alexreyes
Sep 30, 2015 11:30 PM
