Help! Swapped my Brembos, Now VDC/BRAKE Lights are ON?
Old Oct 10, 2006 | 06:45 AM
LBC TRD's Avatar
LBC TRD
Default Help! Swapped my Brembos, Now VDC/BRAKE Lights are ON?
I have a G35 Coupe, and I swapped my Brembos off for stock 350Z brakes, it was a direct swap and nothing complicated was involved. But after the swap was completed, I took it for a test run and the "VDC OFF" "SLIP" and "BRAKE" lights were on, then I restart my car and they turned off. Two days later theyre back on, now they wont turn off. My car is still under warranty and is completely stock. It has to be some sort of quick fix or maybe a sensor, anyone that could help would be appreciated. Thank you!
Old Oct 10, 2006 | 07:25 AM
HyperSprite's Avatar
HyperSprite
Mad Scientist
Check the brake fluid level.
Chris
Old Oct 10, 2006 | 08:23 AM
DavesZ#3's Avatar
DavesZ#3
Check the wheels speed sensor connectors.
Old Oct 10, 2006 | 10:13 AM
LBC TRD's Avatar
LBC TRD
How and where would i find the connection for the speed sensors?
Old Oct 10, 2006 | 10:48 AM
LBC TRD's Avatar
LBC TRD
Just checked the brake fluid level, it's at the MIN line, should i put more?
Old Oct 10, 2006 | 11:12 AM
dklau33's Avatar
dklau33
Defintely. When the fluid gets too low all those lights you described will come on. When you bled the brakes after the swap why did you not fill the fluid to the top?
Old Oct 10, 2006 | 12:14 PM
LBC TRD's Avatar
LBC TRD
They filled it up, but i guess it needs more.. i'll try it. Thanks.. keep em coming.
Old Oct 10, 2006 | 12:41 PM
gqong's Avatar
gqong
topping the brake fluid will do it. the sensor is telling you its getting too low.
Old Oct 10, 2006 | 05:22 PM
LBC TRD's Avatar
LBC TRD
It worked.. thanks you guys. I was getting pretty freaked.
Old Oct 10, 2006 | 07:21 PM
buffmanjeff's Avatar
buffmanjeff
Awesome Tai, glad it worked out. The brembos look great on my car.
Old Oct 11, 2006 | 07:29 AM
Gilley's Avatar
Gilley
Why did you swap the Brembos for stock Z calipers, unless you are selling the car? I assume you swapped the rotors as well.
Old Oct 11, 2006 | 08:46 AM
THE TECH's Avatar
THE TECH
It's always the easiest things.
Old Oct 11, 2006 | 05:30 PM
buffmanjeff
he's trading in the car
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
