Installed: Stance coilovers-problem with knocking/thuds in rear
Old Oct 10, 2006 | 07:24 PM
brigz's Avatar
brigz
Default Installed: Stance coilovers-problem with knocking/thuds in rear
I recently installed a set of Stance coilovers over the weekend with a buddy. While testing them out, im getting a really bad knock from the rear drivers side. Even from the smallest bumps in the road there are some thuds and knocks. Can anyone help me zero in on the problem. I already check to make sure the collars are tightened and preload was readjusted. I really want to push these to see how much better they are compared to stock but dont want to do so with the gremlin knocking in the back.
Old Oct 11, 2006 | 04:19 PM
brigz's Avatar
brigz
Question
Old Oct 11, 2006 | 04:38 PM
skidmarq's Avatar
skidmarq
Did you remove and inspect the pillow mount on the top of the coilover?
Old Oct 11, 2006 | 06:06 PM
brigz's Avatar
brigz
I just came back from taking off the coilover and i found out that the top nut was loose. After tightening that the ride was smooth and much better, but since the old knocking is gone the other rear i found out, has a very minor one that i will have to adjust.
Old Oct 12, 2006 | 08:23 AM
sen_jen's Avatar
sen_jen
post back with your thoughts about the coilovers.
Old Oct 12, 2006 | 09:15 PM
brigz's Avatar
brigz
Overall handeling was much improved and the car is more predictable. I kept the damper level at 6/6 and its not bone jittering at all. The ride is smooth and larger bumps are precise. Body roll has been decreased with the coilovers but sways will fix that.
The only problems i had was the loose top nut on the one rear coilover.
I see a potential problem with the rubber bushing that connects to the bottom of the coilover (since all the force is now being put on that one connection). Mine has some very minor cracking which looks pretty new. When i had the car set really low i could see that it was being twisted more than it should be, stretching out and compressing the bushing at a extreme angle.
Does anyone know if there there any solid bushings for rear coilover set ups?
Old Oct 18, 2006 | 10:43 AM
three_fitty's Avatar
three_fitty
+1... not sure how long those bushings will last. I can definitey see the cracks forming on mine.
As for the thumping, i got the same problem.
Old Oct 18, 2006 | 03:55 PM
axolotol81's Avatar
axolotol81
What kind of thumping is it? Does it sound like metal to metal? I recently installed my Stances also, but I don't have any thumping sound unless I go over a really deep hole. I will be checking everything this weekend since I am going to be putting all the front and rear SPC camber parts I finally got. Also, how low are your guys' cars? Mines pretty low, but again no noise.
Clint
Old Oct 18, 2006 | 04:51 PM
brigz's Avatar
brigz
I set mine to have the fenders a cm over the top of the tire. I forgot to measure the stock distance from the center of the wheel to the fender. Anyone have that on hand?
Old Oct 18, 2006 | 08:12 PM
philude's Avatar
philude
i have the same exact problem. it's annoying as hell.
it started on my passenger side, so i switched it to the drivers side to see if it was the problem, and it persisted. what can it be? it feels stiffer than the other side although i have them at the same setting.
Old Oct 18, 2006 | 09:36 PM
abui01's Avatar
abui01
I had a thud thud thud noise going over bumps as well, 2 words for you guys: End Links!!! Problem solved, check out the end link thread for pics of my install.
Old Oct 20, 2006 | 12:52 PM
three_fitty
Does anyone know where i can get a solid bushing for the rear? I've looked all over the place but no luck.
I do know they make em, saw them on the Midori Skyline
Old Oct 21, 2006 | 11:08 AM
dewuser's Avatar
dewuser
Could you post a link to the "END LINKS" thread?
Thanks
Old Oct 21, 2006 | 11:40 PM
axolotol81's Avatar
axolotol81
How long have you guys had your Stance coilovers on? My rear bushings seem just fine. They aren't wrinkled or cracked looking at all. I've been riding on them for about 2 weeks now and they seem fine.
Old Oct 30, 2006 | 03:00 PM
dewuser's Avatar
dewuser
I have my Stance's on for about 2000 miles. The top bushing on the rear knuckle looks fine on my Z!
Old Oct 30, 2006 | 04:24 PM
dewuser's Avatar
dewuser
Here is a suggestion:
https://my350z.com/forum/showthread....57#post2931057
