Tanabe GF210 vs Hotchkis??
Old Oct 11, 2006 | 08:50 PM
bklusa1's Avatar
bklusa1
Default Tanabe GF210 vs Hotchkis??
The GF210 is obviously a lower drop.... does anyone with either of these springs have any serious issues with speedbumps? I was thinking the GF210's because of slightly more of a drop.... however if scraping/speedbumps are going to be a serious problem then I might go with the Hotchkis. Any kind of input on either of these springs would be great... thanks. I'm used to driving a lowered vehicle, but the GF210's look reallllll low... dunno if maybe it's just the way the shadows are being cast in the pics I've seen or not..... also was thinking about pairing them up with either the Dspec's or Koni Yellows (Most likely the dspecs though). Thanks again!
Old Oct 12, 2006 | 04:59 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
The Tanabe is definitely among the lower springs out there, and if you live in an area like we do (Long Island, New York) where the roads are not all wonderful, you may find them a bit too much. Tanabe are a bit more expensive as well.
We've had alot of local guys using the Hotchkis lately, and from 2003-2006 models, they work amazingly well.
Old Oct 12, 2006 | 05:20 AM
BlackZero6's Avatar
BlackZero6
i like my gf210s.....they honestly dont look that low to me...maybe its just my eyes
cali roads are pretty bad, but i dont have a hard time getting around
Old Oct 12, 2006 | 06:38 AM
Andy@Performance's Avatar
Andy@Performance
Performance Nissan
I like the drop on the Tanabe's, they ride like stock yet improve steering response and you can feel a little less roll. The only advantage to the Hotchkis spring in my opinion is that theyre linear rates where the GF210's are progressive.
Old Oct 12, 2006 | 04:10 PM
liudacris's Avatar
liudacris
+1 on GFs
Old Oct 12, 2006 | 04:28 PM
solidsnake's Avatar
solidsnake
if you want to be able to drive into any driveway or speed bump without the fear of f***ing up the bottom then get hotchkis.
Old Oct 12, 2006 | 11:03 PM
Dubai's Avatar
Dubai
+1 Hotchkis
Old Oct 13, 2006 | 12:43 AM
gimpster621's Avatar
gimpster621
+2 tanabe
Old Oct 13, 2006 | 01:15 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
I wish my hotchkis lowered a little more in back.
If you want the good looks, go for tanabe. If it's not just for looks, hotchkis
Old Oct 17, 2006 | 11:24 AM
xkevon's Avatar
xkevon
what about eibach?
Old Oct 19, 2006 | 06:39 AM
Gsedan35's Avatar
Gsedan35
I would run Koni's with GF210's IMO, use D-specs.
Old Oct 19, 2006 | 07:32 AM
chill47's Avatar
chill47
+1 hotchkis.........alot of potholes in NYC..........
Old Oct 24, 2006 | 12:38 AM
kourosH's Avatar
kourosH
which hotchkis???
Old Oct 24, 2006 | 04:14 AM
Z1 Performance
Former Sponsor
Hotchkis only makes one set of springs
Old Oct 24, 2006 | 05:00 AM
jadaniya's Avatar
jadaniya
if i buy the hotchkis springs i wouldn't need to buy anything else right? I could just put them on and get a realignment and my car would be lowered and run without problems?
Old Oct 24, 2006 | 05:08 AM
Z1 Performance
Former Sponsor
most likely yes, but depends on your wheels and tires, as well as the alignment settings your car is starting with (Nissan sets them merely to a range from the factory)
Old Oct 24, 2006 | 12:56 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Correct unless you start rubbing after alignment.
Old Oct 25, 2006 | 02:15 PM
bklusa1's Avatar
bklusa1
Default rubbing?
Is this a typical problem after the hotchkis install?
Old Oct 25, 2006 | 02:19 PM
DRFTER_Z's Avatar
DRFTER_Z
Sorry to change the subject but anyone/shop have them in stock...... performance nissan has them on backorder, Thanks
Old Oct 25, 2006 | 02:23 PM
Z1 Performance
Former Sponsor
as with any car/drop it depends on your wheels - you certainly won't have any issues with stock wheels, only with the aggressive size/offsets Z guys like to run - even then, some cars never rub, as its subject to the specific tires you choose
We've got Hotchkis in stock yes
Paul.
Oct 16, 2015 07:34 PM
RiujinZero
Sep 25, 2015 01:19 PM
MRJDMZ33
Feb 25, 2004 05:14 AM
MRJDMZ33
Feb 17, 2004 09:45 PM
