sway bars...
Old Oct 25, 2006 | 05:31 AM
kayfuNk's Avatar
kayfuNk
Default sway bars...
i heard that sway bars will pretty much ruin your ride on a daily driver.. it's a little rough and bouncy?? I do know that it helps greatly on the handling aspect but has anyone experienced a huge jump in the way your 350 rides as far as smoothness when you put on your sway bars?
Old Oct 25, 2006 | 05:36 AM
JCZ33's Avatar
JCZ33
I prophesy a thread move to the suspension section.
Old Oct 25, 2006 | 05:50 AM
chimmike's Avatar
chimmike
sway bars do nothing to the ride...............who told you that?
I didn't notice a single change in the ride quality with my hotchkis bars.
Old Oct 25, 2006 | 06:00 AM
njsho's Avatar
njsho
Sway bars indirectly help the ride. If you didn't have swaybars, you would need much stiffer springs to maintain the same level of body roll, which would ruin the ride.
Old Oct 25, 2006 | 09:01 AM
DavesZ#3's Avatar
DavesZ#3
First off, the Z already has swaybars. It has a tight, rough ride but that's caused by more than just the sways.
Adding stiffers sways are supposed to affect the ride on rough roads, but I personally haven't noticed any difference. A rough ride is still a rough ride.
From the Wikipedia on Sway Bars:
http://en.wikipedia.org/wiki/Sway_bar
Drawbacks
Because an anti-roll bar connects wheels on the opposite sides of the vehicle together, the bar will transmit the force of one-wheel bumps to the opposite wheel. On rough or broken pavement, anti-roll bars can produce jarring, side-to-side body motions (a "waddling" sensation), which increase in severity with the diameter and stiffness of the sway bars.
Old Oct 25, 2006 | 02:06 PM
kayfuNk's Avatar
kayfuNk
thanks, yea my friend used to have a civic.. i guess those dont come standard with sways? so he put them on and said the ride was way bumpier.
Old Oct 25, 2006 | 08:58 PM
z-u-later's Avatar
z-u-later
I think you're confusing the sway bars with the springs.
Old Oct 26, 2006 | 07:11 AM
Q45tech's Avatar
Q45tech
Sway bars are usually less than half [20-50%] the stiffness of springs [actual wheel rate] and don't fully engage [rubber bushings] until the first inch of body roll to reduce the impact of minor street bumps.
Old Oct 28, 2006 | 12:05 AM
Mellowman's Avatar
Mellowman
just installed my cusco sways and i haven't noticed much difference in bumpiness, but a HUGE difference in the turns. Once I get my coilovers then the ride quality will dramtically change.
hulkout
Apr 28, 2017 09:00 PM
Paul.
Oct 16, 2015 07:34 PM
RiujinZero
Sep 25, 2015 01:19 PM
