OK, So who has installed the SPC Camber Shims? w/out ABS, VDC, SLIP light coming on?
Old Nov 25, 2008 | 02:08 PM
  #41
warmmilk's Avatar
warmmilk
Originally Posted by STIsaad
I just got off the phone with Technical Support from SPC... they said the that you only need to use the spacers if you need negative camber.. the camber Arm will only give you positive camber... so before installing these if you car has negative camber you can install just the arm to correct the negative camber to brin you to 0 or a little positive. If you have nay questions you can call the Technical Support Line at 1-800-525-6505. They re very helpful and are aware of the issues with ABS and TCS...
will you not be able to run *any* negative camber at all without the shims installed, or just not alot of negative camber? say i want stock or .5 degree more negative than stock, is that possible without the shim?
aarrgghh
May 1, 2022 11:04 AM
emooheo
Oct 14, 2015 08:58 AM
TrackFiddy
Sep 24, 2015 09:36 AM
HoneyBadgerRy
Sep 21, 2015 03:25 PM
