Mismatching brake pads front and rear
Old Dec 13, 2006 | 10:50 PM
Cloud's Avatar
Cloud
Default Mismatching brake pads front and rear
I have the non brembos and I'm thinking of gettin Endless Super Street Y pads. However endless only makes them for the front.
Will it be ok if I got SS-Y pads for the front only and then something else like SS-S for the rears? I really prefer the high initial response of the SS-Y pads.
Old Dec 13, 2006 | 11:00 PM
zand02max's Avatar
zand02max
Won't matter.
Old Dec 13, 2006 | 11:06 PM
Cloud's Avatar
Cloud
so do the front brakes do most of the braking ? I often see front brake pads only or front bbk's only.
Old Dec 13, 2006 | 11:07 PM
Ianmtx's Avatar
Ianmtx
Yes most of the braking is done by the front wheels.
Old Dec 14, 2006 | 01:39 AM
Azn_Empurio's Avatar
Azn_Empurio
i highly doubt brake pads would perform that much better? i mean it does its job right?
calipers and rotors yea i can see that
anyone care to correct?
Old Dec 14, 2006 | 02:57 AM
SpeedRcr's Avatar
SpeedRcr
pads have a big affect on how braking is...if you get cheap pads you can tell the difference...higher quality pads don't fade and are less prone to premature wearing...but hey if your life is worth 20 bucks go for it
Old Dec 14, 2006 | 04:59 AM
Q45tech's Avatar
Q45tech
Use an IR gun to measure the temperature rise of the rotors under an extreme stop [multiple measurements for accuracy]...........graph and look at front rear ratios.
Ideally they should be close.
An interesting read is the detailed test done on Police cars showing the different temperature from just a dozen different pad brands. This correlates to pedal pressure and wear rates and stopping distance. Some brands fried the rotors compared to oem while not stopping better
http://www.nlectc.org/pdffiles/brakepads_epr2000.pdf
Old Dec 14, 2006 | 10:20 AM
first350's Avatar
first350
I run different pads front/Rear for track days to help the fronts grab a little better - I like the results...Raybestos R41 (front) and R43 (rear).
-Peter
samansharif
Sep 25, 2015 12:31 PM
