Brakes: r1concepts
Old Dec 27, 2006 | 01:56 PM
Default Brakes: r1concepts
I bought 4 rotors plus pads from r1concepts on eBay. Total cost less than $200 including shipping. I have been shopping for brakes, and found rotors that cost $200 each. Thats too much for my budget. I plan to install front brakes this weekend, and will write a critique of my initial impressions.
Old Dec 27, 2006 | 05:50 PM
Triple8Sol's Avatar
Triple8Sol
You didn't go with crossdrilled or slotted or both?
Old Dec 27, 2006 | 07:34 PM
Scarab440's Avatar
Scarab440
cross drilled and sloted offers more form than function on a street car.
davidv - nice pics. are there any mfg's stampings on them? I would be curious to know if they are off the same production line as some of the more expensive brands.
Old Dec 28, 2006 | 01:10 AM
aleok's Avatar
aleok
^ yes please tell us how the look and compare to the stock rotors, and why didn't you go for the drilled/slotted ones?
Old Dec 28, 2006 | 06:59 AM
THE TECH's Avatar
THE TECH
Hmm. I personally wouldn't put random brake rotors on my Z.
Old Dec 28, 2006 | 07:53 AM
MoodDude's Avatar
MoodDude
Is it the picture, or are the vains straight? The vains should be curved like a fan blade so when the wheel rotates it pulls air from the center and flowing it to the outside this then cools the rotor.
Old Dec 28, 2006 | 08:08 AM
SpoilsofWar's Avatar
SpoilsofWar
Curved vane venting is not found on all rotors, usually only higher end ones. Many rotors have straight vanes.
Old Dec 28, 2006 | 12:51 PM
guitman32's Avatar
guitman32
Good find!
Those are for non-Brembo right?
Old Dec 28, 2006 | 01:59 PM
StopTech's Avatar
StopTech
Vendor - Former Vendor
You may want to paint the hub and vane areas of the rotors with a high temp coating since the unprotected unswept areas will begin to show surface rust immediately.
Old Dec 28, 2006 | 02:06 PM
Originally Posted by guitman32
Good find!
Correct.
Old Dec 28, 2006 | 02:46 PM
aleok's Avatar
aleok
i thought R1 coats ther rotors with E-coating or whatever its called to prevent rust?
Old Dec 28, 2006 | 02:54 PM
Triple8Sol's Avatar
Triple8Sol
Not true. Even street cars driven aggresively can benefit from this stuff. Either way, why would you get blanks, and not at least slotted for the same price? I dont' get it...
Old Dec 30, 2006 | 01:53 PM
Front brakes installed today. Installation was straight forward except for removing the rotors. It takes some serious banging with a hammer to get them off. I bed the brakes. They are quiet and very similar to the OEM brakes.
Will follow up at 10,000 miles.
Special thanks to Joseph Brinkmeier for garage, tools and patience.
Old Dec 30, 2006 | 02:50 PM
MoodDude's Avatar
MoodDude
Drilled and slotted are not for everyone, and for a street driven vehicle unless you want the agressive look I would not recommend getting either.
Slotted rotors scrape away a small amount of pad surface so that a new fresh pad surface is presented to the rotor, thus given you better braking. But, you will wear your pads out faster with a slotted rotor. The slotted rotors also allow for a more localized cooling and can cause premature failure in extreme cases.
Drilled rotors allow gas built up between the rotor and brake pad to escape, thus eliminating the risk of brake fade due to the pads. Yet, the holes will also scrape away a small amount of pad surface at a localized spot, thus contributing to uneven pad wear, and if the pad is matched to an the application you will not get this "gas". Also, the holes will allow for better cooling in a localized spot thus increasing the chance of rotor failure.
So unless you are using the car for a road track, I would stay away from both as you will replace rotors and pads more offen with slotted and drilled. Again, unless you are going for looks.
In either case, if you are looking for performance from a rotor, it is better to spend your money on curved vains instead of slotted or drilled.
Old Dec 31, 2006 | 01:29 AM
aleok's Avatar
aleok
^, what about slotted and drilled? twice as bad? about how long you think with just regular street driving, the rotors and pads could last?
Old Jan 3, 2007 | 03:51 PM
Kolia's Avatar
Kolia
Plain is the best IMO
Get the right pad and you wont get fade...
Old Feb 5, 2007 | 12:23 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
+1
Old Feb 5, 2007 | 02:45 PM
+1
Sorry but no. The box with the pads is generic and mentions no brand name.
Old Feb 5, 2007 | 02:50 PM
THE TECH's Avatar
THE TECH
I think they were asking if there were any stamped markings on the rotors. Usually they are on the outside circumference of the rotor.
Old Feb 5, 2007 | 03:03 PM
Eazzy's Avatar
Eazzy
Fact is --Iv been buying for several yrs now, rotors for various vehicles from F-350s to all Imports from Napa that are made overseas with good results---Price: 30-55.00 each. Give em a shot David and let us know.
