Spring install - reuse upper rubber seat??
Old Jan 1, 2007 | 08:09 PM
Cloud's Avatar
Cloud
Default Spring install - reuse upper rubber seat??
After installing the HKS hipermax RS at the shop, I noticed the upper rubber seats for the rear springs (the ones that look like a thick rubber funnel) isn't put in. Do I need to put it in?
Old Jan 1, 2007 | 08:28 PM
carfi179's Avatar
carfi179
got to put the rubber back!
Old Jan 1, 2007 | 11:11 PM
Cloud's Avatar
Cloud
Need more feedback on this before i take it back to the shop
Old Jan 2, 2007 | 05:12 AM
350zspl's Avatar
350zspl
http://www.meganracing.com/products/...d=437&catid=93
i used these
i did not re-install rubber cone
Old Jan 2, 2007 | 07:45 AM
Gsedan35's Avatar
Gsedan35
No, because you can't and could not even if you wanted to.
As a habit I save pictures of coilover systems, in case I need to refer back and examine them for this or that. I have a picture of a RS and II setup with all the part's spread out. On the II I can plainly see a rubber pad under the upper spring mount. In the RS picture I cannot clearly see a pad, but IMO it has to be their.
Old Jan 3, 2007 | 05:15 PM
Cloud's Avatar
Cloud
so the 2 upper rubber cones won't fit. I thought it would sit on top of the rear springs just like the OEM.
Old Jan 3, 2007 | 05:26 PM
showstoppertk's Avatar
showstoppertk
NEVER reuse a rubber. didn't you learn anything in sex ed jk
on the s-tech springs I believe the install manual actually says to reuse the rubber, but then on my flex coilovers you don't.
Old Jan 3, 2007 | 10:17 PM
Cloud's Avatar
Cloud
this is what I was referring to as the rubber spring seats.
Old Jan 4, 2007 | 10:56 AM
Cloud's Avatar
Cloud
update: I called HKS USA and they told me to reuse the upper rubber seat?
Old Jan 4, 2007 | 11:33 AM
97supratt's Avatar
97supratt
The rubber is to stop any squeaking or noise from the spring being in contact with the upper support bracket.
Old Jan 4, 2007 | 11:44 AM
06blueZ's Avatar
06blueZ
That looks like a bumpstop, and you want to keep that if you can fit it in there...
Old Jan 4, 2007 | 11:45 AM
Cloud's Avatar
Cloud
mine squeaks and pops
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
