Brake Rotor Info.
Old Jan 3, 2007 | 10:47 AM
Hot_Foot's Avatar
Hot_Foot
Default Brake Rotor Info.
Looking at replacing my OEM rotors with these cross slotted drilled rotors. This is suppose to be a plug and play installation for 4 rotors at $200.
Does anyone have any advice before I pull the trigger on this purchase
Click Here!
Old Jan 3, 2007 | 11:56 AM
z-u-later's Avatar
z-u-later
One friendly advise -- do a search on "drilled rotors" in this forum. Problems with cracking. Most members are going with slotted rotors. Good price though.
Old Jan 3, 2007 | 01:43 PM
MoodDude's Avatar
MoodDude
Please read my comments on this thread before ordering anything:
https://my350z.com/forum/brakes-and-suspension/239311-brakes-r1concepts.html
Old Jan 5, 2007 | 09:55 AM
Hot_Foot's Avatar
Hot_Foot
Who sells just a slotted rotor that will replace the OEM?
Old Jan 5, 2007 | 11:21 AM
mgl's Avatar
mgl
http://www.mynismo.com/products/?id=4900
Old Jan 5, 2007 | 02:56 PM
Search is a great tool: https://my350z.com/forum/showthread.php?t=239311
Old Jan 5, 2007 | 02:58 PM
Check eBay for rotor 350Z. You will find a dozen sellers.
Old Jan 8, 2007 | 10:40 AM
Hot_Foot's Avatar
Hot_Foot
Here is my deal:
$260 for 4 Drilled and slotted rotors and 4 extended life pads including shipping cost. They also offer group discounts as well. I feel this is a high quality rotor for the price and I also found the ebay prices were higher than buying directly from Rotor Pro’s (972-276-5858 Juan Vasquez). Their ebay rating is 99.6 positive on service and parts they sell.
Thank for all the Help!
www.rotorpros.com
http://www.centricparts.com/prod01.htm
Old Jan 22, 2007 | 03:35 PM
Hot_Foot's Avatar
Hot_Foot
Got them on!
I weighed all four rotors when they arrived 61.5 lbs. OEM rotors weighed 56.5 lbs a 5 lb difference. Thought the drilled slotted rotors would weigh less to my surprise that was not the case. So far I am pleased with look and fit, and quality. There is a better braking feel and the pads they provided appear to be low dust (no black wheels) and quiet at this point. Will keep you updated after a few more months of driving.
Old Jan 26, 2007 | 04:33 AM
Scarab440's Avatar
Scarab440
i wonder if the weight diffrence is because your comparing a used rotor to a new one. you should reweigh the rotor you just installed when it gets worn out and compare the numbers again.
Stevo Z
Oct 3, 2015 09:14 PM
samansharif
Sep 25, 2015 12:31 PM
