Coilovers with easy rear damping adjustment
Old Jan 10, 2007 | 05:16 PM
spratocaster's Avatar
spratocaster
Default Coilovers with easy rear damping adjustment
I have seen that a lot of coilovers have the damping adjustment at the top of the damper. It seems that this would make it near impossable to adjust in the rear. Since I would like to be able to adjust at the track, which of the available coilovers for the Z are easy to adjust damping in the rear?
Old Jan 10, 2007 | 05:17 PM
bb1314's Avatar
bb1314
da Terminator!
Tein? You can even buy the EDFC and control the damper force in your car.
Old Jan 10, 2007 | 08:21 PM
anotheraznguy's Avatar
anotheraznguy
one of the few and i've owned a set
are zeal coilovers.
they have it at the bottom so all you do is reach into the wheel and adjust bam!
Old Jan 10, 2007 | 08:41 PM
spratocaster
Is there anything the zeals don't do? Unfortunately, you have to pay for such thorough engineering. $3K is a bit much for my budget. Any others with easy adjustment that are less than $2K?
Old Jan 11, 2007 | 01:21 PM
spratocaster
Thats it? Zeals or EDFC?
Old Jan 11, 2007 | 06:10 PM
grnfrog8's Avatar
grnfrog8
I heard that the HKS coilovers have the same setup as the Zeal coilovers. The adjustment ***** are located at the bottom, so all you have to do is get out of your car, reah into the wheels, & adjust.
Old Jan 11, 2007 | 07:21 PM
anotheraznguy
i think i played w/ some hks's but from what i recall they were on top..
but then again..
that was a loong time ago maybe someone w/ them can chime in
Old Jan 11, 2007 | 07:45 PM
first350's Avatar
first350
I drilled 2 small holes on the rear strut bar to be able to access mt JIC's adjustment *****...for track/AutoX, I just remove the rear plastic cosmetic panels - super easy to adjust.
-Peter
...some ppl have tried using adjustment cables that attach to the top of the coilover - that way you can snake it through the inteior panelling...but they've said those cables don't attach very well.
Old Jan 11, 2007 | 07:54 PM
MIAPLAYA's Avatar
MIAPLAYA
My HKS coilovers have the adjusters at the bottom and with my LE37Ts all I have to do is reach in between the spokes to adjust my dampning.
Old Jan 12, 2007 | 09:25 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
HKS are on the bottom, so are Bilstein
Old Jan 22, 2007 | 02:25 PM
TwoK4drSi's Avatar
TwoK4drSi
All HKS coilovers have it at the bottom or just the certain ones?
Old Jan 23, 2007 | 05:01 PM
Axelerate's Avatar
Axelerate
All of them.
Old Jan 23, 2007 | 06:09 PM
Jokestrap's Avatar
Jokestrap
The new Greddy Type S coilovers have ***** that come through the panels. I have had them for about 8 months. I have tracked my car with them many times. The adjustment is great. Go from soft to firm in seconds and they are great coilovers.
Old Jan 23, 2007 | 06:19 PM
Z1 Performance
Former Sponsor
yep ^ very easy to adjust
Old Jan 24, 2007 | 06:03 AM
Lawn Dart's Avatar
Lawn Dart
RS*R I-shock
Old Jan 24, 2007 | 08:58 AM
Gsedan35's Avatar
Gsedan35
Originally Posted by Lawn Dart
RS*R I-shock
I like the specs. But honestly, have they ever been imported here with support from RSR and what about the repair question? I saw in G35 coupe in a import mag that had them, that's it.
