Tein Tie Rod Ends now available for Z33/V35!
Old Feb 1, 2007 | 09:51 AM
Andy@Performance's Avatar
Andy@Performance
Performance Nissan
Default Tein Tie Rod Ends now available for Z33/V35!
http://www.mynismo.com/products/?id=4014
Old Feb 1, 2007 | 09:54 AM
Volk350Z's Avatar
Volk350Z
Master
nice.. hmm do i need it lol
Old Feb 1, 2007 | 12:43 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
yessssssss great for drifting!!!!!!!!!!
Old Feb 1, 2007 | 01:33 PM
sentry65's Avatar
sentry65
the burninator
anyone know what the stock ones look like?
I got my JIC tie rod ends a month or so ago, but haven't had them put in quite yet, probably next week
Andy, are the tein tie rod ends some sorta spherical ball bearing bushings or something stiffer than stock? That picture isn't very well lit to really see much
Old Feb 1, 2007 | 05:23 PM
daytona350z's Avatar
daytona350z
humm, so you hav to buy the whole setup for it to work? i am currently using s14 tie rod ends made to fit the 350z rack, but i think they are getting worn since i have some play in my steering wheel
Old Feb 1, 2007 | 07:36 PM
Gsedan35's Avatar
Gsedan35
Have to admit, not a area that I've don't a bit of research on. Outside of the reason's that a drifter would want them. Why would I want them. Or vs oem they are different how,......?
Old Feb 1, 2007 | 07:51 PM
jinsei888's Avatar
jinsei888
LOL
it adds great driftzorz power!!!!
on a serious note, i'm sure these are of some decent help in increasing steering angle
Old Feb 1, 2007 | 08:17 PM
Triple8Sol's Avatar
Triple8Sol
Tighter turning radius probably.
Old Feb 1, 2007 | 09:40 PM
anotheraznguy's Avatar
anotheraznguy
ok
so...
outside of drifting this is pretty much useless..
it provides more angle..
also this is good for...
#1 parallel parking.
making u -turns
and if u road race and run across berms alot this will help..
however i don't see much people having issues w/ tie rods braking from abuse
Old Feb 2, 2007 | 06:06 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
speak for yourself...I've done mine 2 times already
My Teins are on the way...never used an aftermarket tie rod or end, but I'll post results come spring when they have been tested
Old Feb 2, 2007 | 06:11 PM
daytona350z
can you do us a favor when you install these? can you check if the tein inner tie rod will fit the stock oem outer rod end?
thanks
Old Feb 3, 2007 | 03:28 AM
o snap its eric's Avatar
o snap its eric
i just want to comfirm that the tie rods can actually increase(tighten) our u-turns. Will these tie rods make our steering more sensitive as well?
Old Feb 4, 2007 | 09:09 AM
bofa's Avatar
bofa
^+1
Alright.. I know nothing about this... do you need inner and outter? Benefit of each? By decreasing the turn radius I'm assuming this means you can turn the front wheels further.. .probs with rubbing? Sorry for al lthe questions.
Old Feb 4, 2007 | 10:30 AM
anotheraznguy
ok..
so they space out the inner tie rod a bit..
these will increase angle
ie.. you can turn steering wheel a little more
however more than likely you will have to trim away at your bumpstops..
wow adam you are just too hardcore for me to be snapping those tie rods..
i snap em in the 240 but not the z yet.
so you get more turning angle and no loss or gain of steering sensitivity it stays the same
Old Feb 15, 2007 | 01:20 PM
Z1 Performance
Former Sponsor
ok just got mine in today - going to be awhile till they are installed since we've got alot going on with my car right now.
I need to sit down and take measurements before I can tell you what these will or won't do though - more to come
Old Feb 15, 2007 | 03:25 PM
JDMFairlady21's Avatar
JDMFairlady21
wow keep us posted adam... i think mine has a lil play, just got front camber arms, might want to install everything one shot...
Old Feb 15, 2007 | 04:23 PM
sentry65's Avatar
sentry65
the burninator
My JIC tie rods are in. The installer said they're way beefier than the stock ones. I haven't driven it yet though
Old Feb 15, 2007 | 04:28 PM
Z1 Performance
Former Sponsor
Alex - we have several sets in stock, so stop down
Old Feb 15, 2007 | 04:34 PM
JasonZ-YA's Avatar
JasonZ-YA
From what ive seen being around drifting and talking to others that have tie rods on their Z's:
If you are a drifter! this is a must have! the Z steering angle is not enough and it then becomes a safety issue.
how you ask:
The z doesnt give enough angle and once you meet or exceed that angle on a drift you are then spun out or loss of drift at least. not a good thing if your at a course with light poles or tire walls...or barriers. OUCH!
- J
Old Feb 15, 2007 | 04:37 PM
JasonZ-YA's Avatar
JasonZ-YA
PM sent!
