help .. totally lost.
Old Feb 5, 2007 | 11:23 PM
nightcrawler_8's Avatar
nightcrawler_8
Default help .. totally lost.
i now guys you will say search but i did 10000 times... nothing similer
i am getting the same clunk sound from the fornt right and left side .. whenever i brake in low speeds and whenever i turn left or right .. i changed the balljoints with new ones and everythign is tight .. but the problem is still there.. what would it be ??? everythign seems fine . .but the sound is still there ..
am really sorry if this is repost but i really need help . i just baught the Z 2 weeks back and am very sad .. i cant even drive it with that sound.. hope you can help ..
thanks in advance
Old Feb 5, 2007 | 11:34 PM
xedes's Avatar
xedes
Did you check to see if your front strut bar is loose?
Old Feb 5, 2007 | 11:36 PM
nightcrawler_8
everything was checked .... nothign is loose at all... cant understand where the noise is coming form ..
Old Feb 6, 2007 | 04:32 AM
z-u-later's Avatar
z-u-later
Did you install an after-market front sway bar? What about after-market springs or shocks? Did you have any work done recently on your suspension/brakes?
Old Feb 6, 2007 | 09:50 AM
nightcrawler_8
totally stock .. nothing was added at all...
Old Feb 6, 2007 | 11:15 AM
Dubai's Avatar
Dubai
Did you take it to the garage you told me about? if not I really suggest taking her to Subzero, I'm pretty sure they'll know where the noise is coming from..
Old Feb 6, 2007 | 11:40 AM
nightcrawler_8
i did take it to that garage
we changed the lower arm and the ball joints and the sound still there .. so i told the gy dont touch it... just let me take it to the agency .
i took it for the 40k service and to check what the hell is worng.
still they didnt reply . they will call me once they know what the hell is wrong .. the car still under warranty i dont know if they will fix it under warranty or no .. am toooootally pissed..
Old Feb 6, 2007 | 07:30 PM
Dubai's Avatar
Dubai
damn hope the dealer can at least know whats going on or else I'd be really pissed!!!
Old Feb 7, 2007 | 07:15 AM
ryan350z's Avatar
ryan350z
new brake pads? If so they might be rocking in the bracket when you stop for the first time you'll get a clunk. Forwards or Backwards, should only happen once then go away when you drive until you change directions IE Park the car then reverse out of a spot.
Good Luck let us know.
Old Feb 7, 2007 | 01:01 PM
nightcrawler_8
no the brake pads rnt new... and the sound is there all the time .. as i said before.. whenever i go in unstable road or go right or left..
Juztin
Nov 22, 2015 07:03 AM
Vigman
Nov 17, 2015 04:34 AM
Jewelz350
Aug 30, 2002 08:35 AM
Brad4rdHay
Aug 13, 2002 08:09 AM
