Cusco Coilover Install and results - many pics! 56k no
Old Feb 12, 2007 | 09:27 AM
nkohler's Avatar
nkohler
Default Cusco Coilover Install and results - many pics! 56k no
The install went well. Took around 3.5 hours. My girlfriend and I tackled the fronts, and then a friend showed up and helped out with the rears.
Impressions: These coils are dampened very well. SO much better dampening than my OEM struts. No noise on the coilovers, and they are very tight feeling and inspire a lot of confidence in the corners driving on the edge of traction. These also eliminated my wheel hop. I am very satisfied.
Currently I have them set on 4/5 on all corners, its a very stiff ride, but dampened well. I think I will keep them there for now.
On to the pics! Click on them for larger pics!
It begins!
Its me!
Wheel comes off
Other side
Hello
Taking off suspension bolts
A-arm bolt off
Hi Jessica!
Old springs/struts
OEM strut/spring gone!
New coilover in!
Workin on it
ooooo adjustment!
Fronts done and down!
Holy camber!
Another look
Aaron and I taking a look at the rear
New rear equipment
Old rear strut versus new rear strut
Rear stuff gone!
Aaron looking amazed
New rear stuff installed!
All old stuff!
Rear coils in and dropped.
I love the new lower look. coupled with the handling its amazing. These coilovers can go a lot lower, and a little bit higher.
Thanks Performance Nissan for a great deal on these!
Neil
Old Feb 12, 2007 | 09:37 AM
Dubai's Avatar
Dubai
nice
Old Feb 12, 2007 | 10:01 AM
teh215's Avatar
teh215
Nice, which ones are they - Zero-1 or Zero-2? Is this car a daily driver?
Old Feb 12, 2007 | 10:04 AM
nkohler's Avatar
nkohler
zero-2, and yes, its a daily driver, but not for long... probably daily for another month.
Old Feb 12, 2007 | 11:00 AM
Resolute's Avatar
Resolute
Good job, it looks nice. The Cusco's are one of my favorites for coil-overs. Top notch.
Will
Old Feb 12, 2007 | 12:03 PM
THE TECH's Avatar
THE TECH
Car looks nice!
Old Feb 12, 2007 | 01:31 PM
Wholey Smokes's Avatar
Wholey Smokes
Looks good man! My coilovers should be in any day now.
Old Feb 14, 2007 | 09:20 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
hope you guys got the non pillowball versions, or I guarantee you'll be replacing mounts within the next 6-8 months...the pillowballs on those make a racket over time unfortunately
Old Feb 14, 2007 | 10:09 AM
nkohler's Avatar
nkohler
I got the non pillowball mount versions yes.
Old Feb 14, 2007 | 10:18 AM
JasonZ-YA's Avatar
JasonZ-YA
are u gonna get any control arms to handle camber issues?
Old Feb 14, 2007 | 10:20 AM
nkohler's Avatar
nkohler
I will see how far off it is after I get an alignment. If its way too far off, then yes I am going to have to. If its not too bad then not right now. This car isnt my daily driver and will be using r-compounds for autocross that love and were made for lots of camber.
Old Feb 15, 2007 | 06:44 PM
maximumsportZ's Avatar
maximumsportZ
To adjust the height do you have to remove the wheels on those coilovers?
Old Feb 16, 2007 | 06:21 AM
Z1 Performance
Former Sponsor
to adjust height on any coilovers the wheels should come off - makes it infinitely easier
Old Feb 16, 2007 | 06:57 AM
nkohler's Avatar
nkohler
agreed. you could probably do it between the spokes of the GT-C's, but you would have to definitely contort your arm to work around.... probably would take just as long to take the wheel off...
Old Feb 16, 2007 | 07:18 AM
r0mey's Avatar
r0mey
very nice
Old Feb 16, 2007 | 07:31 AM
maximumsportZ
Right, just sucks if your trying to eye each side to sit the exact same with the wheels on.. I guess you could set a measure point on the coils... I'll probably get these coming soon.
Old Mar 8, 2007 | 04:15 PM
shinkuu's Avatar
shinkuu
would you recommend this for a strictly track set up? i'm looking into their sway bars and deciding on a coilover to go with too.
Old Mar 8, 2007 | 04:56 PM
nkohler's Avatar
nkohler
nah, you could run these on the street just fine, just set them to soft. but they do stiffen up very nicely if you like.
Old Mar 8, 2007 | 08:55 PM
Endless Shock's Avatar
Endless Shock
Cool
How long have you had these on now? You have rubber mounts instead of pillowball mounts? Do they "squish" going over speed bumps? How low are you?
I have the same setup as you but I have pillowball fronts and hard rubber rears... I have about 7000 miles on them and they just recently started to "squish"...
Here is a pic of mine...
Attached Thumbnails Cusco Coilover Install and results - many pics! 56k no-ritz-680n.jpg   Cusco Coilover Install and results - many pics! 56k no-ritz-680n-03.jpg
Old Mar 9, 2007 | 05:17 AM
nkohler's Avatar
nkohler
I have rubber mounts, and they have around 500-1000 miles on them now and no noises yet!
