StopTech 13" BIG BRAKES DO fit OEM 17" Wheels
I never saw a pic of this combo, so I was a little leery of hearsay....I took the plunge.........and they DO fit
Feeling frisky, as I watched the snow melt, I guessed that Winter is over, so time for the Wonderful 040's.......
All I had to do was remove the OEM wheel weights (PITA), which rubbed the caliper, and reapply aftermarket stick on weights closer to the outer rim.
Originally posted by Rob Nance
That is scary to me. It just seems like it should have some room to breathe.
If you want to find out if your wheels will fit without spacers, you can download the following template and print it out, then cut along the dotted line. Insert it into a (dismounted) wheel and rotate it 90 degrees to make sure it clears both the barrel and the spokes.
350Z 332mm brake kit template
EnthuZ - I haven't installed a 350Z kit under this particular wheel before. Would it be OK if I borrowed your photo for my web site? I'm building a wheel library for each platform. Here's an example of one for the BMW E39 5-series and M5 platform: http://www.zeckhausen.com/bmw_instal...photos.htm#E39
Thanks!
1 mm is very risky in my opinion.
OEM spec(s) range from 3 to 6 mm at max grown dimensions. (Largest caliper casting + heat)
Also by moving the balance weights, you have effected the dynamic balance of the wheel-tire assembly, but I doubt this will cause too much noticeable vibration.
The weights in this particular case were transplanted outward in the same radial plane as they were originally located. The distance was probably no more than 1/4". While technically, you are correct, the real world effect of this is typically negligible since 1/4" easily fits within the error of your average human operator who stuck the weights on in the first place. Assuming the wheels were perfectly balanced before, it would make sense to remove a tiny bit of weight prior to moving them outboard by 1/4" but if you actually calculated the amount, it would be smaller than the minumum step in weight sizes.
Yes, I moved the weights outwards about 1/2", and I do not feel any vibration at all. The wheel spokes clear the caliper about 5/8" or 14mm. I feel comfortable with the set up. The 3/16"(4mm) clearance between the caliper and the wheel "barrel" is more than adequate. Geese, the caliper would have to balloon, say, 30% to cause an issue!
DZeckhausen, feel free to use the pics as you please. My Pay Pal account is:........J/K
For Dynamic Balance, Lateral placement is important (not as important as radial, but important just the same.) But the wheels on my car are not dynamically balanced right now, and I no objectionable vibration, so I think the Z is not particularly sensitive to this.
On clearances, I would want more on a road car then a track car... You would be surprised what can make its way between calipers and wheels...
Sound like you are in good shape.
xirtam
Oct 3, 2015 02:06 PM
350Shadow
Sep 22, 2015 08:30 AM
VQA33
Wheels Tires
Sep 8, 2015 08:30 PM
