Tein S-Tech Lowering
Old Mar 18, 2007 | 12:24 PM
DJMatrix1067's Avatar
DJMatrix1067
Default Tein S-Tech Lowering
This is possibly in the wrong section but:
I looked at three different vendors for the Tein S-Tech Lowering springs for my z. the first said it would lower the car by .6 inches. the second said approximately 1.5 inches of drop. the third said some other number.
does anyone have S-tech springs or know how much they will actually lower a Z?
Old Mar 18, 2007 | 12:28 PM
Phantom Menace's Avatar
Phantom Menace
+1...I, too am confused about Tein's claims. In pictures, it looks like it lowers atleast 1.5" yet they claim something like 0.6 in the front and 0.3 in the rear, then most advertisments will say that it "lowers the vehicle 1.5"?"
Old Mar 18, 2007 | 12:34 PM
Demon Z's Avatar
Demon Z
I'm pretty sure the accurate numbers are .6 in front and .7 in back. I'm thinking about a set myself. It's pretty subtle.
Old Mar 18, 2007 | 12:35 PM
furiousZ's Avatar
furiousZ
Just as curious. I've gone to hear is a 1'' drop. I am going to purchase some soon after I decide if I want to keep my axle back or not.
Old Mar 18, 2007 | 12:50 PM
Phantom Menace
The pics I've seen online do not look anywhere near "conservative." Actually the pics I've seen of Eibachs (1" drop all around) look much more conservative. Here's a pic I just found of a 350 on S-tecs:
Old Mar 18, 2007 | 12:51 PM
DJMatrix1067
well see i want my z to look lower...i was thinkin an inch or more. but the word on the street is that if you do that then u have to get a camber kit, and i cant afford that plus the springs
Old Mar 18, 2007 | 12:52 PM
DJMatrix1067
ya but the reason why that may look so aggressive is cuz hes probably sittin on 19s or 20s. im 18's so the wheels will look smaller in the wells and have more room.
Old Mar 18, 2007 | 12:57 PM
Jes-Z's Avatar
Jes-Z
Actual Drop is .8 R & .6 F. I measured. These are 19''. I don't rub on speed bumps or anything.
Old Mar 18, 2007 | 01:02 PM
DJMatrix1067
so do we need to worry about camber or no?
Old Mar 18, 2007 | 01:05 PM
Jes-Z's Avatar
Jes-Z
at full adjustment you will barely be into negative camber. Adjustment is pretty close to factory spec. It's at the limits of factory spec.
Old Mar 18, 2007 | 01:19 PM
Blacryan's Avatar
Blacryan
Well can anybody tell me where they ordered the 1's that are .6 and .8!? Because I want to order the exact same set of springs :-)
Old Mar 18, 2007 | 01:39 PM
DJMatrix1067
www.google.com
type in Tein S Tech lowering Springs.
Old Mar 18, 2007 | 01:56 PM
Shift_Z33's Avatar
Shift_Z33
After the fact, I wish I had bought the Tanabe GFs instead of the stechs. Oh well.
Old Mar 18, 2007 | 02:00 PM
DJMatrix1067
why is that?
Old Mar 18, 2007 | 02:37 PM
Shift_Z33's Avatar
Shift_Z33
b/c they are lower and have a lower spring rate. Seems like a win win for a street car
Old Mar 18, 2007 | 02:43 PM
Kevins350z's Avatar
Kevins350z
i just put the stech on my car not too long ago. the drop is desent and it closed up the wheel gap. my cambers in the rears are -2.2 and -2.3 and the guy who did the alignment told me it's been maxed out.
Old Mar 18, 2007 | 03:02 PM
hardrock905's Avatar
hardrock905
I had the tein S-tech springs installed about 3 years ago and I believe these numbers are correct.
I took the Z to a performance alignment shop afterward and they were able to get everything very close to spec. I haven't had any trouble at all with the camber.
IMO, the drop looks great. Did away with the annoying wheel gap.
Old Mar 18, 2007 | 03:25 PM
Jes-Z's Avatar
Jes-Z
I measured the gap before i switched with a caliper and then 3 months after to give a good estimate. I ended up with .8 R and .6 F.
Old Mar 18, 2007 | 05:52 PM
JoeyFyed's Avatar
JoeyFyed
Im running them on stockers. Its a good drop for a stock looking Z, .7 front, .6 back.
Old Mar 18, 2007 | 06:10 PM
z-u-later's Avatar
z-u-later
I had Tein S Tech springs on my '06. The drop is actually more in the front than the back, approximately 3/4" in front & 1/2" in rear. It gives your Z a more aggressive stance with the front slightly more lowered. If you'd like to see pictures of my Z with the Tein S Tech springs, just click on my signature block below.
NOTE: I just recently changed my springs to the Espelir Active GT springs since it has a higher spring rate for auto-x.
