wtf my Tein S.Tech drop is crooked
Old Mar 25, 2007 | 10:28 AM
Pooplet's Avatar
Pooplet
Default wtf my Tein S.Tech drop is crooked
I just noticed on my rear left drop is 1 finger fender gap and the right rear side is 2 finger wide gap. Springs have settled for about 1 month now. Is my kit defective or something?
Old Mar 25, 2007 | 11:40 AM
sry110's Avatar
sry110
I have a similar phenomenon with my Hotchkis springs. The driver side rear is slightly more gap than the passenger side rear (maybe 1/4"). I took wheel arc height measurements before the spring install and the OEM springs yielded the same results, driver side had more gap than passenger side. Not sure why this is.
Old Mar 25, 2007 | 11:45 AM
gregtotheb's Avatar
gregtotheb
wow thats crazy because mine has a bigger gap on the drivers side too with nf210's i got them done a couple of weeks ago and i was just waiting it out till they settle, but either way it still looks good. we'll see what happens.
Old Mar 25, 2007 | 11:48 AM
350beast's Avatar
350beast
It's been a little over a month for me and It still does not seem my teins have settled. I guess that's a good thing. Anyhow, all sides seem even on my teins.
Old Mar 25, 2007 | 03:53 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
1. make sure you are parking on a perfectly level section of pavement....use a level to verify it
2. it is VERY common for aftermarket springs to give a slightly uneven drop side to side. This is not an issue with the springs, nor with your car, as it can happen on a wide variety of springs and a wide variety of cars.
Also, the springs do not settle....not good ones at least. It's actually the rubber upper strut mount that compresses slightly, and that happens within a few hundred nmiles of driving usually.
Old Mar 25, 2007 | 07:38 PM
HyperSprite's Avatar
HyperSprite
Mad Scientist
3. Double check that the springs are positioned in the lower cups correctly.
Chris
Old Mar 26, 2007 | 07:53 AM
Mazinger Z's Avatar
Mazinger Z
Same thing happened w/ my Hotchkis springs (passenger side about 2mm higher) but that was in my garage. Make sure you are parked on even ground. Sometimes I check and the drop is even...at least it made me feel better that I'm not the only one
apex locator
Jul 23, 2021 02:27 AM
3vilbunny
Jul 18, 2017 05:10 PM
