urgent response needed.. Camber and toe arms
I put in the rear camber arms, do i need toe adjustment arms or bolts as well. I cant really afford them but Z-1 told me if i adjust camber i will throw off toe and will need toe bolts.
Originally Posted by Drift_corners
where do i buy them
not familiar with those at all, but you should ask what you should now do for toe adjustment - since one affects the other automatically
the SPC kit which most people use includes provision for camber and toe adjustments
http://www.z1auto.com/prodmore.asp?m...ng&prodid=1314
Yes adjusting camber is going to throw the toe out of spec. Yes you should buy the SPC toe bolts. No $45 isn't THAT much for some eccentric bolts that drop in with little modification and save your $1000 set of tires from being destroyed.
if you want just the bolts, i got mine for $25 here:
http://www.prosuspension.com/product...roducts_id=439
I didnt check to see if they carried the the camber arms though.
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
