Coilover Dampening Adjustment Knob Stuck..
Old Apr 5, 2007 | 03:02 PM
ThreeFiveZero Z's Avatar
ThreeFiveZero Z
Default Coilover Dampening Adjustment **** Stuck..
I went out today to soften up the coilovers from full stiff and my driver side front is stuck. I removed the top to show the allen key fitting and tried the right size and it wont budge...anyone ever have this problem..I have the greddy coilovers btw
Joseph
Old Apr 6, 2007 | 01:17 PM
Gsedan35's Avatar
Gsedan35
Joseph
The problem relates to having to stick a allen key into the top to prevent the piston shaft from turning when the upper nut is tightened. Sometimes in the process you end up jamming the adjustment screw so it end's up locking in place as your experiencing. All I can suggest is to make sure your turning in the right direction and make progressive attempts that are firmer and firmer until you win and your able to make the change your after.
Old Jul 30, 2022 | 05:00 AM
mrk003's Avatar
mrk003
Hi all, while I don't own a 350z, I've just today had the same problem shortly after installing some Blitz ZZ-R's. the driver side damper adjuster **** is stuck and I believe the issue is as stated above, occurred when I tried to tighten the top nut. I was just wondering whether I should stick simply stick in a 3.5mm (that's the size it seems) hex key into the adjuster and turn it clockwise (when I was tightening the top nut, the counter direction of this was anti-clockwise). Very confused and I'm over installing coilovers on cars manufactured in recent years. Any help would be greatly appreciated, thank you in advance.
PintofBrew
Apr 22, 2017 09:32 PM
Fixxxercask
Jun 10, 2012 09:50 AM
MB350zz
Apr 19, 2007 04:25 AM
