Need new brakes...help
Old Apr 7, 2007 | 06:06 PM
z_roadster's Avatar
z_roadster
Default Need new brakes...help
Ok so my brakes have been squeeking for a while now, but i just noticed some grinding noises. So i'm taking the car to Nissan on monday and I guess i'll probably need new brakes right?? If I do, should I get nissan to buy them and install them or will they just rip me off? I want brembo's but they are probably gonna cost me quite a bit, anyone have any ideas for how much more than stock brakes? Are brakes suppose to wear this fast? My car only has 19000km's on it so 11806miles. What do you guys think I should do considering that i'm on a budget. and just to be sure, brakes aren't under warranty are they? thanks
Old Apr 7, 2007 | 06:11 PM
ldawg32's Avatar
ldawg32
are you on stock bremros now? if not you will have to upgrade your whole brake kit. i have the hawk pads on now and love them no squeek and a lot less brake dust. go with them prob your best bet
Old Apr 7, 2007 | 06:13 PM
dunglan7's Avatar
dunglan7
Go with the Hawks if you want less dust and less squeek. Go with OEM pads for better bite.
Old Apr 7, 2007 | 06:58 PM
Ztalker's Avatar
Ztalker
DIY and save...dealer will charge an arm and a leg for brembos.
Old Apr 7, 2007 | 10:53 PM
z_roadster's Avatar
z_roadster
shiat, how much do hawks go for?? and yeah im on oem brakes right now not the brembos.
Old Apr 8, 2007 | 12:30 AM
z_roadster's Avatar
z_roadster
also, do I just need new pads?
Old Apr 8, 2007 | 09:33 AM
I replaced my OEM front brakes at 48,000 miles. I cannot tell if you need pads or rotors or both without measuring them.
Old Apr 8, 2007 | 09:39 AM
randymack's Avatar
randymack
Default hawk
just got hawk ceramic for $119. shiiping included from pr racing.com. they are on sale now. very good brakes. got them in 3 days,too!
Old Apr 8, 2007 | 10:42 AM
Fluid1's Avatar
Fluid1
The Hawk HPS pads have less initial bite as the OEM pads, so be warned. I'll be going to the HP+ when these are done.
Old Apr 10, 2007 | 04:46 PM
z_roadster's Avatar
z_roadster
So i took my car into nissan today and got an estimate. They are charging me $620 CAD so $540USD for the two front rotors and pads with install! So I'm just going to order front and rear hawk pads along with 2 front oem rotors. What do you guys think? I'm not too familiar with brakes, and have never worked on them, but I found a good DIY for brake pads. Is it easy to change the rotors? any special steps? again, I've never worked on brakes before. thanks
Old Apr 10, 2007 | 06:30 PM
Here’s a secret: penetrating spay on the...
calliper bolts
rotor bolts
rotors
Let it sit for 20 minutes minimum.
Old Apr 10, 2007 | 06:46 PM
Scarab440's Avatar
Scarab440
^^ Davidv speaks the truth (always)... I would add a breaker bar to the list.
it is pretty eay to change them. since you have non brembo and maybe driving in the snow belt I would think about renting or borrowing a three jaw puller to deal with a stuck rotor.
Old Apr 10, 2007 | 07:16 PM
[/IMG]
LOL. The 2 bolts on the back of the calliper are mothers! Torque must be 110 pounds!
Old Apr 10, 2007 | 07:26 PM
Ztalker's Avatar
Ztalker
harbour freight got those jaw pullers...inexpensive btw.
one of my front rotors was loose when i was replacing the pads and the other one was on pretty tight. i guess the rear ones will be a b!tch to remove.
Old Apr 10, 2007 | 08:26 PM
z_roadster's Avatar
z_roadster
starting to contemplate installing myself... what kind of grease do i need to apply on the brakes? and are the rotars that hard to remove? and how can i torque the bolts at 110 pounds when im screwing them back on?
Old Apr 10, 2007 | 09:37 PM
Ztalker's Avatar
Ztalker
starting to contemplate installing themself... what kind of grease do i need to apply on the brakes? and are the rotars that hard to remove? and how can i torque the bolts at 110 pounds when im screwing them back on?
a breaker bar or an impact wrench is required to loosen the bolts and you will need a torque wrench to tighten those 22mm bolts up front. If your not handy with tools or mechanically inclined, i wouldn't recommend DIY. Some rotors are pretty much frozen in place and even some seasoned mechanics might have a hard time removing them. You don't apply grease to the brakes... use liquid wrench or WD-40 to loosen the bolts before hand.
i once used WD-40 to soak the bolts the night before removing the exhaust in the morning.
Old Apr 10, 2007 | 09:50 PM
Justin@WestCovinaNissan's Avatar
Hawk pads are good, typically quiet and not too much brake dust. Use HPS for more street usage or HP+ for the track enthusiast.
You might also want to consider something like Endless or similar pad. Endless has a more streetable pad and a few lines that are more track oriented.
Being where you are a dealer could be quite expensive to do a brake job. Oftentimes a local mechanic or, as mentioned, doing it yourself will be much more economical.
While you're at it, this would be a time to upgrade to a better brake fluid (i.e. Motul RBF600 or Super Blue). These fluids have a higher boiling point, giving your a firmer pedal and better braking during spirited performing much better than any conventional fluid.
Old Apr 10, 2007 | 10:34 PM
z_roadster's Avatar
z_roadster
thanks for the info guys, and justin, would you know how much a dealer would charge for the install if i bought the parts?
