brembo track brakes
Old Apr 12, 2007 | 04:27 PM
nismo*son's Avatar
nismo*son
Default brembo track brakes
Does any one know if you can buy the brembo track edition brakes and install them on a non-brembo Z. Would there be modification involved? Thanks
Old Apr 12, 2007 | 05:22 PM
Scarab440's Avatar
Scarab440
buy everything(calipers,rotors,pads,brake lines,bolts,fluid)
remove old brakes
trim the dust shields
install new harware
its not a bad install...
DavesZ#3's Avatar
DavesZ#3
Yes you can install the OEM Brembos on another Z. I don't recall seeing a DIY on it, but if you search this forum (Brakes & Suspension), you might find some related posts. If I remember correctly, you'll need different brake lines too.
Old Apr 12, 2007 | 09:42 PM
nismo*son's Avatar
nismo*son
thanks
Old Apr 13, 2007 | 07:10 AM
THE TECH's Avatar
THE TECH
The harder part of the install is whether you want to replace the stock dust shields or just cut them.
Old Apr 14, 2007 | 10:16 AM
Michla22's Avatar
Michla22
Indeed I just did this install on my car - got used brembo's and resurfaced rotors front and rear , ss lines and bolts (rear only - fronts are same bolts).
Before:
After:
Old Apr 14, 2007 | 10:23 AM
Chako135's Avatar
Chako135
good info
Old Apr 14, 2007 | 08:47 PM
TheProfessional's Avatar
TheProfessional
Where can I pick up a set of gold brembos?
Old Apr 15, 2007 | 01:53 AM
Armitage's Avatar
Armitage
Check the classifieds here. I've seen a set go here and there, for pretty cheap too. Good bargain IMO.
Old Apr 23, 2007 | 10:28 PM
Michla22's Avatar
Michla22
https://my350z.com/forum/brakes-and-suspension-diy/266223-diy-for-stock-non-brembo-to-stock-brembo-brakes.html
