Cheapest brake upgrade
Old Apr 12, 2007 | 07:31 PM
whitenizmo's Avatar
whitenizmo
Default Cheapest brake upgrade
Anyone know the cheapest way to upgrade your brakes? I feel my non-brembo oem brakes is not strong enough...but I dont want to spend another 2k for a new set..any suggestion?
Old Apr 13, 2007 | 03:16 AM
Q45tech's Avatar
Q45tech
Since you live in a cold climate careful about researching after market pads. As you raise the peak operating temperature it comes off the bottom. Good high temp pads will be BAD low temperature pads............before you warm rotors and pads up to 150-200F. This can let you blow thru stop signs in winter.
The oem high dust [carbon particles] is there to tweak the cold and initial bite to resolve problems..........low dust pads may not be so good in Canada winters.
Could your problems be tires not operating at correct tread temperature?
Summer performance tires are pretty useless below 50F.
Old Apr 13, 2007 | 05:44 AM
whitenizmo's Avatar
whitenizmo
I got two set of tires, winter tires and my summer tires. I dont put on my summer until late April or May...so what you mean is low dust pad is mostly for warming region right?
Old Apr 13, 2007 | 06:43 AM
Kolia's Avatar
Kolia
We're discussion non-Brembo brake upgrades 2 topics down yours...
https://my350z.com/forum/brakes-and-suspension/263392-whats-a-good-way-to-upgrade-the-z-brakes.html
Old Apr 13, 2007 | 08:08 AM
THE TECH's Avatar
THE TECH
Good tires will be your biggest friend in braking better if you plan to keep the stock calipers.
