10/8kg spring rates on JIC FLT-A2
Old Apr 13, 2007 | 03:55 PM
vince1611's Avatar
vince1611
Default 10/8kg spring rates on JIC FLT-A2
Old Apr 13, 2007 | 05:19 PM
first350's Avatar
first350
I'll be interested to hear your results...I run the same coilovers and do autoX. So far, the adjustability of the shocks feels like I'm able to tune the car to dail out under & over steer...but the biggest variable is still my driving
Old Apr 14, 2007 | 04:01 PM
dklau33's Avatar
dklau33
From what I've read, 12kg is too stiff in the rear and doesn't keep the tire planted on the road. Relatively softer rear springs will help maintain traction.
Old Apr 14, 2007 | 04:11 PM
sentry65's Avatar
sentry65
the burninator
my thought process was always with a 53/47 weight distribution, to have the fronts be slightly stiffer than the rears. You can always adjust shocks, tire pressure, sway bars, and tire sizes to change from over to understeer
Old Apr 15, 2007 | 06:12 AM
Gsedan35's Avatar
Gsedan35
Originally Posted by vince1611
I've decided to get new springs+revalve for my FLT-A2's. The current setup at 10front/12rear is ofcoarse very oversteery and makes the car handle like a muscle car on the autocross. Despite my current sidewalls being too stiff, the A2's sit into turns fairly well. Many companys seem to like using a 10/8 setup and I'm trying to figure out exactly why. I'll be switching to RE-01R's in the future for the softer sidewalls so that I get more grip, but I suspect that it still won't help much. I know some of you have LOTS of experience with different spring rates, so any advice appreciated.
I have experience running many different rate combo's in testing and agree with what your thinking about doing.
Read posts 76,77,78,79 and 80 in the thread below.
https://my350z.com/forum/brakes-and-suspension/53332-developing-a-faq-page-for-suspension-4.html
Old Apr 15, 2007 | 02:23 PM
vince1611's Avatar
vince1611
Old Apr 15, 2007 | 08:12 PM
Gsedan35's Avatar
Gsedan35
Excellent! That was the explanation I was looking for!
Fiddling with the tire pressure diddn't do enough. I wasn't clear about this earlier, but my main problem was controlling oversteer in the middle and exit of the turn while powering out. I've tried softening the rear shocks but that mostly only effected the entry of the corner. I suppose tire size and sway bars will help, but I'm thinking that it would be better to get the springs right in the first place, instead of having to compensate for it.
If I did my multiplication correctly truechoice uses a 9/7.5 set up. In that case, I think I'll either go with a 10/9 or 9/8 setup to counter the understeer caused by my nismo LSD. What do you guys think?
Setting the spring rates first is the ideal way to go, though not everyone has dampning that allow's for much variation in getting to that ideal rate point. Only you can ultimately decide what is the best. In the revalve process, Jic should tell you that you'll have a +or- 2Kg rate range to play with. If you have then valve to a 10/8 setup, you would be able to do either rate your thinking about.
Old Apr 16, 2007 | 01:53 AM
WA2GOOD's Avatar
WA2GOOD
Keep in mind, just because JIC (or any company for that matter) says their spring rates are xxK doesn't mean that they actually are. I have tested MANY coilovers for various companies for track and street use for these cars and have found out the hard way that you need to personally rate test each spring yourself. For example...... I personally tested a set of JIC FLT2 springs that the coilovers came with. They claim that they are 10K front 12K rear. I personally tested them to actually be 541LBS or 9.68K for the fronts and found the rears to be 395LBS. or 6.44K. Pretty big descrepincy, huh? So, from personally experience and from my race car chassis background, I rate every spring personally before installing it, so I know what it is exactly I am installing.
Old Apr 16, 2007 | 06:40 AM
Gsedan35's Avatar
Gsedan35
Are you sure you didn't have part #Z33FLTA2S in hand vs Z33FLTA2H? That would explain the rear rate
http://www.jic-magic.com/ViewProduct...art=1#AppChart
Old Apr 16, 2007 | 08:48 AM
WA2GOOD's Avatar
WA2GOOD
Valid point, but I am sure they were the H'es.
Old Apr 16, 2007 | 10:06 PM
vince1611's Avatar
vince1611
Old Apr 17, 2007 | 08:38 AM
Gsedan35's Avatar
Gsedan35
Vince, I found something that I knew about, but had forgotten. You'll want to read this.
Originally Posted by FritzMan
I ran the JIC in a hybrid setup with 10 kg (560 lbs) front and 9 kg (502 lbs) rear. I then switched to 12kg (672 lbs) front and kept 9 kg rear when using the stock sways. The JIC package is supposed to be configured with a 10 kg front and 12 kg rear. I have no idea why they chose such a stiff rear but I suspect their setup is tuned for stock sways and stagger tires. For my setup of 245/40 all round and Hotchkis sways med f & r, I think 10(f) and 9(r) was the perfect street/track mix with a JIC package.
Their selected spring rate bias is very similar to what I'm now running with my JIC FLT setup. Instead of the standard kit of 10kg front and 12 kg rear (560/672 lbs), I'm running 10 kg up front and 9 kg rear (560/502).
The softer rear provides a lot more corner exit traction while the stiffer front allows agressive turn-in and sharper steering response. Not only has handling improved, but I found that a softer rear really improves the street ride. It seems as though the rear is more sensitive to spring rates than the front.
I ran the 560/672 all last season in Solo2 and felt the rear was too snappy. It was good for rotation but bad for weight transfer/traction when exiting corners. Also, any kind of bump would upset the tire's traction because the rear was just too stiff.
Throughout the '04 season I played with sway bar rates and the JIC's adjustable compression and noticed that a softer rear allowed more traction without ill effects to handling. The car certainly felt different, but the clock (and butt) said it was a good move.
This season I'm setting up the car for Solo1 so an even softer rear is ideal (some understeer). Initial testing with the current setup has been quite favorable.
Note that I'm running 245/40/18 Kumho MXs front AND rear so understeer has been substantially tamed with that setup alone.
When asked this question.
"I know this is a subjective topic but how is the street ride to you with your 10kg/9kg setup? Okay for you as an everyday driver? And what are your thoughts in terms of performance if I were to get lets say a 9kg/8kg FLT-A2 setup?"
I'm quite pleased with how the car is riding ride now. Frankly, it depends a lot on road conditions in your area but in Canada we can get some pretty rough stuff due to frost upheaving etc.. Because this is a year-round daily driver I refuse to compromise driveability for the sake of performance.
The best thing about this setup is that the shocks can be noticably stiffened up when you want to play so to a certain extent you can get the best of both worlds.
I wouldn't worry so much about softening the front rate as the rear. For example, I autocrossed this weekend and ran the front dampers full stiff and kept the rear full soft (handling was fantastic). I had to drive off the lot (to the john) and was surprised how decent the ride still was with the front full stiff. IMO, softening the front much more would result in brake dive and loss of steering precision.
I guess what I've saying is that 10/8 setup should work well and save you the cash of having to separately purchase the front springs ($120 for both).
Old Apr 28, 2007 | 11:53 PM
vince1611's Avatar
vince1611
Old Apr 29, 2007 | 04:24 AM
Lawn Dart's Avatar
Lawn Dart
I'm using Cusco coilovers (10kg front/7kg rear) and anti-roll bars (120% stiffer front/173% stiffer rear), a setup similar to what you are suggesting. It handles phenomenally.
To quote Resolute:
To keep the car flat through a turn it uses pretty big ant-roll bars.
If you raise the spring rate too high out back you'll have wicked oversteer on acceleration out of a turn.
After reading that, it confirms why my RS*R springs (6.17kg front/7.46kg rear) combined with my Cusco anti-roll bars handled like poopoo.
I agree with you vince1611, I think you should change the spring rates and valving. However, I think you should pair it with a stiff rear adjustable anti-roll bar, like Hotchkis.
AARONHL
Nov 23, 2015 06:00 AM
350Zenith
Jan 31, 2013 05:38 AM
2TH PWR
May 12, 2012 05:58 AM
supergoji
Apr 28, 2010 06:54 AM
spratocaster
Feb 7, 2007 01:00 PM
