Swift Spirings
Old Apr 19, 2007 | 12:54 PM
captj3's Avatar
captj3
Default Swift Spirings
Does anyone have these springs on there Z? How would they compare to Teins. The only thing I know about them is they are JDM. Any info would help in my decision on buying them. Thanks in advance.
Old Apr 19, 2007 | 12:59 PM
Nihilation's Avatar
Nihilation
Swift's are one of the best street/track performance springs available for the 350z. Combine them with a set of Tokico D-Spec shocks and you're golden.
Old Apr 19, 2007 | 01:46 PM
captj3's Avatar
captj3
How much of a drop are theses? How is the ride on them? Which ones did you get? I'm looking for a minimal drop and I'm also getting Tokico D spec shocks.
Old Apr 19, 2007 | 01:49 PM
Nihilation's Avatar
Nihilation
It was roughly .8" front and .6" drop in the rear. I leave my Tokico's on the stiffest setting for daily driving and I feel that it's perfect. Expect -1 degree of front camber and -2.5 in the rear, get a set of SPC rear control arms for $180 from Z1 and have them installed at the same time.
Old Apr 20, 2007 | 07:31 PM
Gsedan35's Avatar
Gsedan35
Tein S-tech 350Z springs .7“.6“ (slightly progressive front, linear rear)
Spring rates in LBS 386/402
Swift 350Z linear springs .8”/.6” drop on 350Z, G35 drop will be higher)
Spring rates in LBS 336/364
We can't proclaim the Swift spring as being a better performance spring in the face of the S-tech having greater stiffness level's. Granted the material used in the wire by Swift is lighter in weight and it's front spring is 100% linear. Both those things don't add up to trump the S-tech. And if we want to split hairs, the front S-tech springs only have 1 maybe 1.5 coil's devoted to being progressive, meaning they will not have a wide variation between initial rate and final rate like several other Z springs that have 3 or more progressive coils.
I don't see either spring as a poor or wrong choice, they both have qualities that I prefer (though both are far to soft for me). 1. Mild drop to promote decent shock piston travel 2. Linear springs (forgiving the S-tech fronts because of only being slightly progressive). 3. Decent front spring stiffness increase over oem (Swift does trail the S-tech in that regard)
Old Apr 23, 2007 | 12:00 AM
ctwentytwo's Avatar
ctwentytwo
What has fortgotten to be mentioned is that SWIFT uses a superior material that is stronger, lighter, and not going to sag over time, compared to almost all the others, which use silicon chrome ... according to SWIFT. The pricing reflects it. If you're a JDM *****, Swift qualifies also.
www.swiftsprings.com "SWIFT advantage"
If you plan on getting a body kit, or if you use this car as a daily driver, the drop is perfect. The 0.6" drop for the rear doesn't seem like much on paper, but it is obvious you dropped your car.
Old Apr 23, 2007 | 04:18 AM
captj3's Avatar
captj3
Thanks for the information.
Old Apr 24, 2007 | 03:49 PM
mavtais's Avatar
mavtais
My install with pics and all. Short term review & long term review.
https://my350z.com/forum/brakes-and-suspension/231140-swift-sport-mach-springs-just-installed.html
I love the swift springs, but they might not be as stiff in the rear as OEM revised springs. Regardless, I am happy with them.
Rickdogg
Southern California
Jan 8, 2006 08:58 PM
