Brake and VDC warning lights
Old May 16, 2007 | 03:31 PM
Sharkey's Avatar
Sharkey
Question Brake and VDC warning lights
I just installed new pads and SS lines, bled all the corners and have good pedal feel and things seem to be grabbing properly. My issue is that the damn VDC light and "brake" lights are remaining lit, as well as the SLIP indicator. what is going on here? I unhooked the battery hoping that would reset the computer and get rid of the lights, and no dice.
I'm off to a track day tomorrow if I can get this sorted out, so any help is appreciated. Thanks, Ken
Old May 16, 2007 | 03:38 PM
Kolia's Avatar
Kolia
Is the fluid reservoir full ?
Old May 16, 2007 | 03:43 PM
Mike Wazowski's Avatar
Mike Wazowski
check the speed sensors and make sure they are still plugged in
Old May 16, 2007 | 04:01 PM
Sharkey's Avatar
Sharkey
I assume that's the other line that I see mounted next to the brakes lines? I'll go check those things now. I thought I might have been prying against one of them when I did the right rear... .(?)....
Old May 16, 2007 | 04:22 PM
Mike Wazowski
yep, if you damaged one of those or it is not plugged in all those lights will pop on
Old May 16, 2007 | 04:25 PM
Sharkey's Avatar
Sharkey
Are they only on the fronts? I dont' have the wheels off this thing and I can't see in there, and now i'm getting pissed. How would I have unplugged it? I guess I dont know what i'm looking for.... wtf. I hate these things! lmao!
Old Jun 2, 2007 | 06:39 PM
tropicalypso's Avatar
tropicalypso
Is it possible to knock one loose or damage one during routine wheel cleaning? I use a long handled brush to get into certain parts of the wheel, and I wonder if I caused myself the same issue. Like the OP, my VDC Off, SLIP and Brake lights are staying lit.
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
