Noisy Hawk pads.
Old May 29, 2007 | 10:57 AM
350redline's Avatar
350redline
Would bleeding the hoses help stop the squealing?
Old May 29, 2007 | 10:59 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
no - the noise has nothing to do with bleeding
Old May 29, 2007 | 11:05 AM
Brick-Z's Avatar
Brick-Z
Same noise here. Even reinstalled the pads and I am still getting the same noise. Plan on swapping the Hawks for a different pad next time.
Old May 29, 2007 | 11:10 AM
Fluid1's Avatar
Fluid1
Originally Posted by Richy350Z
I bought the same ones from Stillen. They make noise, lots of it.. kind of embarrasing. They sound like if i didn't have brakes at all. It's only at times when it makes that noise , after driving the car for a while. I have been contacting stillen, but they've been hiding.
Why in the hell would you be contacting Stillen?
And why in the hell would you buy Hawk pads from them?
Old May 29, 2007 | 11:19 AM
Z1 Performance
Former Sponsor
guys...you need to properly bed them in, use the shims and use anti squeal.
When done correctly, they will not make any noise at all
Old May 30, 2007 | 07:15 PM
Keltin13's Avatar
Keltin13
Same situation with my roadster. Where do you get the shims and anti squeal?
Old May 31, 2007 | 03:36 PM
Beau's Avatar
Beau
Well, I'm back from my weekend at Shenandoah and they still don't squeek or squeel.
I used the backing shims, tons of the anti-squeel brake goo, and that's it.
In my opinion, if you install these correctly you will not have any noise.
Old Jun 27, 2007 | 01:56 PM
hockiman90's Avatar
hockiman90
where do you get these shims and anti squeal goo youve been talkin about?
Old Jun 27, 2007 | 02:11 PM
Beau's Avatar
Beau
The shims were on the existing pads. I got the anti-squeel goo in little tear open packets at Advance Auto by the cash registers.
Old Jun 27, 2007 | 04:11 PM
350redline's Avatar
350redline
Yep, i used the goo stuff too and they squeel. I have no idea! Im just gonna get new pads and (maybe) some new OEM rotors.
Old Jun 27, 2007 | 05:49 PM
JCZ33's Avatar
JCZ33
you need anti brake squel spray.
Old Jun 27, 2007 | 07:20 PM
guy121's Avatar
guy121
Hey I was wondering about the squeal grease that you use. I have not changed the brakes on my Z yet, but at some point I'm going to change them. I was wondering where the grease goes exactly?
It goes piston->shim(wear bar metal piece)->pad->rotor right? So now where does the grease go?
Old Jun 28, 2007 | 05:36 AM
JCZ33's Avatar
JCZ33
Well I use Anti Sieze on my Bolts/nuts. But when my old rotors and pads got low, I sprayed the anti squeek right on the rotor(cool rotor/not hot) and the next time I drove the juice hit the pad and squeek gone for about a week. It does not fix anything really, just postpones the fact that pads/rotors need replacing.
Also, I've experienced brake dust caking up in the slotted/drilled rotors, causing squeeks. FIX: scrape that studff out with a small flat head or get some brake cleaner and spray it out.
350Z_Al
Oct 29, 2020 07:44 PM
SanmarinoZ
Oct 21, 2015 10:04 AM
jaewonkim
May 9, 2003 03:17 AM
