Good Spring and Shock/Coil overs for a Daily Driver
Old May 25, 2007 | 09:11 AM
DaytonaRoadster's Avatar
DaytonaRoadster
Default Good Spring and Shock/Coil overs for a Daily Driver
I been searching lots of threads and i cant seem to narrow it down. I'm looking for a Daily Driver Spring Shock comb, or Coilover system. My Z is pretty much for the weekend, and i dont think it'll see a track more than once or twice.
I been looking at the Tein Basics, but i heard goods and bads. I really dont want the car to set much lower than it is ( i have 19' SSRs) maybe just the back.
So what do you guys recommend?
Old May 25, 2007 | 09:20 AM
kwiker's Avatar
kwiker
Shift_Dorifto
Bilstein PSS9.
Old May 25, 2007 | 11:09 AM
DaytonaRoadster
eh looks like those run around $1500, a little more than i want to spend. I was looking around a grand. Maybe $1200
Old May 25, 2007 | 11:37 AM
Art Vandaleigh's Avatar
Art Vandaleigh
Nismo setup will suit you just fine. No adjustments needed and handles fantastic.
Old May 25, 2007 | 11:59 AM
DaytonaRoadster
Yeah i was looking at that too, since its factory warranited also
Old May 25, 2007 | 04:26 PM
Lawn Dart's Avatar
Lawn Dart
Tokico D-spec with springs
Old May 25, 2007 | 04:29 PM
DaytonaRoadster
i had those on my prelude, there where good, but they didnt last long, maybe 2 years
Old May 25, 2007 | 05:14 PM
Lawn Dart's Avatar
Lawn Dart
Good luck finding a set of "coilovers" that out-last D-specs.
Old May 25, 2007 | 07:13 PM
DaytonaRoadster
i didnt say i wasnt considering all options, i'm just telling past experiance
Old May 25, 2007 | 07:17 PM
blaukal's Avatar
blaukal
I like my Nismo and would recommend it, but wanted to point out that it is "no adjustments possible" -- it's a plug and play system, unlike most coilover setups. It also drops the car 3/4", which you indicated you might not want.
Old May 25, 2007 | 09:53 PM
Gsedan35's Avatar
Gsedan35
Basics can do a oem ride height, but only by dialing in the absolute maximum amount of spring preload or 2.4" worth. Not something I'd recommend even if it can be done, doesn't mean their isn't a price to pay for doing it that way. Tein recommends a 1"/.8" drop.
Based on what you want I could see Tein H-tech's with Tokico D-specs, you'll get a mild drop and a mild increase in spring stiffness in the front.
Bilstein PSS9 would be a better choice then the Basics, only vise I don't care for is how the setup uses progressive rate rear springs with a wide spring rate spread.
Keep in mind that most cheap coilovers tend to be underdampned. Not everyone here can or will sense what that means to the ride and drive experience, but your better off with quality shocks like D-specs or Koni SA's. Otherwise spend a little more to up your budget into at least the $1500 range.
Old May 25, 2007 | 10:38 PM
DaytonaRoadster
ok, that helps alot, thanks guys
Old May 26, 2007 | 10:43 AM
JCZ33's Avatar
JCZ33
D-SPECS/SPRINT springs/HOTCHKIS sway bars: rides and looks like a dream.
Old May 26, 2007 | 04:48 PM
Triple8Sol's Avatar
Triple8Sol
Tein Basic or Hotchkis springs w/D-Specs
Old May 26, 2007 | 05:12 PM
Gsedan35's Avatar
Gsedan35
1.5" drop = not enough bump travel on oem based shocks, unless our tighening up the shocks as a method to soften the impact of hitting the bump stops, which is in of itself not the way to do things. Glad you ok with it, just not a choice I'd go with.
Old May 26, 2007 | 07:25 PM
Sensi09's Avatar
Sensi09
Works Concepts
What happened to them?
Old May 27, 2007 | 06:01 AM
DaytonaRoadster
i had no idea, it was my daily driver, and it got tracked maybe 3-4 times, but after 3 years, 3 were blown, i replaced them with KYBs before i sold the car.
Old May 28, 2007 | 09:06 AM
JCZ33's Avatar
JCZ33
This is not the case with my car.
Old May 28, 2007 | 11:06 AM
Axelerate's Avatar
Axelerate
I have HKS RS coil-overs and I am very happy with them, no complaints. I also do track events and auto-x on them and they perform fine.
They fall into your price range and are well dampered for the rates.
Old May 29, 2007 | 09:34 AM
JCZ33's Avatar
JCZ33
The HKS are nice.
