Camber / Toe Issue...
Old May 28, 2007 | 07:41 AM
TuscaniJon's Avatar
TuscaniJon
Default Camber / Toe Issue...
I am having problems getting my rear alinghment done properly... My car is lowered on tanabe gf210 which is about 1.2-1.5 inch drop... I have rear camber arms but I can't get it into spec, do I need to by the radius arms as well to help this issue? The camber arms I have are megan racing which has a good rang of adjustibility. What have you guys done to fix this problem, I just want even tire wear on the rear.
thanks
Jonathan
Old May 28, 2007 | 07:49 AM
sgshap06's Avatar
sgshap06
If you have aftermarket camber arms and the alignment place can't get it back into spec as far as camber then you might want to go to a different shop. Also camber, ultimately effects toe with our cars so the more they adjust your camber your toe could be getting out of spec.
But it seems to me that the shop doesn't know what they are doing, because it should be fairly easy to get the rear into spec w/ aftermarket arms.
Old May 28, 2007 | 07:54 AM
TuscaniJon's Avatar
TuscaniJon
I took it to a NTB, they said I could not get into spec even if adjusting it with my camber arms... So what your saying is that I am able to get it into spec with just the camber arms, like I said I just want even tire wear.
Old May 28, 2007 | 08:01 AM
sgshap06's Avatar
sgshap06
Do you have a previous alignment sheet?
I had mine lowered with the exact same setup as yours and it was pretty far off when I went to get it aligned. But with the aftermarket camber arms(mine being intense motorsports) it was easy for them to get it back into spec.
Either your alignment is absolutely horrible to start out with or they aren't doing something right..
Old May 28, 2007 | 08:07 AM
TuscaniJon's Avatar
TuscaniJon
I don't know where my sheet is... how in spec are you? on target, good, decent, just there? thanks for the help so far
Old May 28, 2007 | 08:10 AM
sgshap06's Avatar
sgshap06
My rears in perfectly in spec.
Do you have aftermarket camber arms?
Old May 28, 2007 | 08:13 AM
TuscaniJon's Avatar
TuscaniJon
yeah I do
Old May 28, 2007 | 09:34 AM
TuscaniJon's Avatar
TuscaniJon
anyone else??????
Old May 28, 2007 | 12:19 PM
redlude97's Avatar
redlude97
you need spc toe bolts, decreasing the negative camber throws the toe out of spec, and won't be adjustable within the stock toe adjustment range. The holes need to be elongated to allow for more adjustment
Old May 30, 2007 | 10:07 AM
Sk8fe's Avatar
Sk8fe
I am having similar problem with rear camber and toe.
Old Jun 1, 2007 | 02:21 PM
TuscaniJon's Avatar
TuscaniJon
I just recieved my SPC bolts, I have four in the package, Where do all of them go?
Old Jun 1, 2007 | 02:45 PM
redlude97's Avatar
redlude97
you only need 2, sell the other two to get some of your money back, they do on the inside bolt of the spring bucket
Old Jun 1, 2007 | 03:09 PM
TuscaniJon's Avatar
TuscaniJon
but in this these pics they are in a different location, attached to the camber arm.
https://my350z.com/forum/brakes-and-suspension-diy/185737-spc-toe-bolt-install-write-up-with-pics-courtesy-of-protocav-4.html
Old Jun 1, 2007 | 03:33 PM
shinkuu's Avatar
shinkuu
at first glance, i thought the title said camel toe issue.
Old Jun 1, 2007 | 03:40 PM
TuscaniJon's Avatar
TuscaniJon
lol that would need to be fixed as well.
TuscaniJon's Avatar
TuscaniJon
https://my350z.com/forum/showthre...=185737&page=4
Old Jun 1, 2007 | 03:48 PM
redlude97's Avatar
redlude97
https://my350z.com/forum/showthread.php?t=185737&page=4
in those pics, it looks like the stock bolts are in the camber arms, and the toe bolts you can't see yet
Old Jun 1, 2007 | 04:34 PM
TuscaniJon's Avatar
TuscaniJon
So just install the ones on the spring bucket? and the other two sell?
Old Jun 1, 2007 | 07:07 PM
Checkmate58's Avatar
Checkmate58
I'm surprise you got 4 toe bolts. Lucky you. Yes, you only need 2.
--Sam
Old Jun 1, 2007 | 09:18 PM
TuscaniJon's Avatar
TuscaniJon
so just the spring bucket gets installed...?
