coilover suggestions?
Old Jun 16, 2007 | 06:41 PM
mestisoZ's Avatar
mestisoZ
Default coilover suggestions?
going to purchase some coilovers here soon. just wondering if anyone had any suggestions on some good ones? and does anyone have the K sport coilover kit on their car becuase they are very good priced just wondering if the ride is bad on them or not.
fr0ng's Avatar
fr0ng
nismo
Old Jun 16, 2007 | 08:13 PM
VENOMSZ's Avatar
VENOMSZ
+1 on NISMO
Old Jun 16, 2007 | 09:36 PM
sleeperZ69's Avatar
sleeperZ69
Eibach
Old Jun 16, 2007 | 11:57 PM
finalforce's Avatar
finalforce
Greddy for me =]
Old Jun 17, 2007 | 06:00 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
budget? uses for car?
Old Jun 17, 2007 | 07:03 AM
Tac-M's Avatar
Tac-M
Originally Posted by fr0ng
nismo
nismo makes coil overs ??? t
i'd say go with eibach.
Old Jun 17, 2007 | 08:16 AM
mestisoZ's Avatar
mestisoZ
yeah not gonna be drifting or anything just want a nice ride hight with a good ride when i put my works on the car. willing to spend up to $1,200 or less on some coilovers. but the k sports caught my eye cause they look great and are fairly cheap
Old Jun 17, 2007 | 08:52 AM
Gsedan35's Avatar
Gsedan35
No the Nismo S-tune suspension isn't a coilover, but those that are recommending it are doing so in a thread where the original poster didn't say how much drop he was looking to get and most that install coilovers rarely take advantage of adjusting the height after the install anyhow. Plus, it's one of best liked system's running on the 350Z we have seen.
Nismo S-tune (twin tube construction, uses progressive springs)
350Z .8"/.8" drop
Spring rates 448/504
Eibach does make a coilover for the Z, well sort of. It's a relabeled KW varient1.
Eibach Pro street S coilovers
Drop range on 350Z 0.8 to 1.6" front same for the rear.
As per Eibach they are relabled KW variant 1 coilovers, springs are a different color simply because Eibach has them refinished red vs yellow.
Spring rates Front 485lbs to 525Lbs Rear: 240Lbs to 548Lbs (progressive springs)
Notes: High progressive rear spring rate spread that cannot be easily fixed because of the mounting diameters of the upper and lower spring seats in the height adjusting system. It still can be fixed, but would require a lot of phone calls and research that most won’t bother with, IMO it’s worth the bother.
Old Jun 17, 2007 | 09:09 AM
Gsedan35's Avatar
Gsedan35
Based on what you want I would consider if your needs would be met by the S-tune setup. Most cheap coilovers may spec well on paper, but let you down when seen from a shock dynamometer, point is that most are underdampned and or oversprung. IMO, pad your max price a bit and consider products in the $1500-$1600 range if a coilover is truley what you you have to have to meet your needs.
On the K-sports, I don't see how they can have the valving magic required to offer decent dynamics given how much spring rate that setup uses. 839lbs/504lbs
https://my350z.com/forum/showthread....ghlight=ksport
Old Jun 18, 2007 | 07:39 AM
SilverJDMCoupe's Avatar
SilverJDMCoupe
Tanabe Sustec Pro S-0C's. I have them on my car and love them!!!!
Old Jun 18, 2007 | 10:48 AM
first350's Avatar
first350
JIC coilovers FTW!
Old Jan 24, 2013 | 01:21 PM
cookies4christy's Avatar
cookies4christy
Anyone have information on ride smoothness of the Tanabe Sustec Pro S-0Cs?
Theyre around $800-$1,000 i believe.
ablaine
Nov 29, 2016 10:13 AM
