Best Lowering Spring? Opinions...
Old Jul 7, 2007 | 01:05 PM
03aeroZ's Avatar
03aeroZ
never mind...forgot to read the above posted threads again.
Old Jul 7, 2007 | 01:51 PM
03aeroZ's Avatar
03aeroZ
so the D-spec with the hotchkis Stage 1 TVS kit would be ok to improve the ride on an 03 and not lower it more then 1'' correct?
Old Jul 12, 2007 | 03:09 PM
inTgr8r's Avatar
inTgr8r
Originally Posted by Gsedan35
Nothing that is 1" or more should be qualified as a "minimum drop", especially knowing first hand how much shock piston stroke is left.
Here are all your choice's in the market for a less then 1" drop
S-techs, Hotchkis, RSR and Swift would get my vote.
Tein S-tech 350Z springs .7“.6“ (fronts are slightly progressive, rears are linear)
Spring rates in LBS 386/402 (estimated initial rate front is 327lbs)
Tein H-tech 350z linear springs .3”/.2”
Spring rates in LBS 358/375
Note: in actuall use stiffness on the car didn't quite match the specs that Tein say's the springs deliver, thats IMO of course.
Hotchkis 350Z Linear springs .6”/.8”
Spring rates in lbs 340/330
RSR 350Z linear springs .6”/.6”
Spring rates in LBS 345/417
Note: Can be difficult to buy, contact vendor or manufactuer directly first.
Swift 350Z linear springs .8”/.6”
Spring rates in LBS 336/364
Kg/mm springs 350Z
DR21 super sport 15mm drop
Spring rates in lbs initial/final front 246/398 initial/final rear 252/409
Espelir 350Z progressive springs 10mm drop or .4”/.4”
Spring rates 386/515 (softer initial rates are unknown)
What about Nismo S?
Is there much drop?
Old Jul 14, 2007 | 12:37 AM
gsazabi's Avatar
gsazabi
Tanabe GF210.
1" front and 1.4" rear drop.
Rowlett
Misc.
Oct 2, 2015 10:38 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
