E-Brake trouble
Old Jul 13, 2007 | 03:31 PM
RedlineZdude's Avatar
RedlineZdude
Default E-Brake trouble
Hey my Emergency brake is really loose and doesnt really hold... has this happened to anyone else and do you have any pointers or tips on tightening it??? thanks
Old Jul 13, 2007 | 03:35 PM
Seyfi1's Avatar
Seyfi1
yup, my 03's hand brake sucks i have to pull it rediculously high for it to barely hold so i put it in gear +hand brake whenever i park. i took it to the dealership when i first got it back in the day and they tightened it but not enough to really help out much.
Old Jul 13, 2007 | 04:24 PM
RedlineZdude
yeah that sounds like mine... well i think im gonna get under it and try and tighten it i just need someone to point me in the right direction for tightening it?!
Old Jul 13, 2007 | 05:04 PM
fklentz's Avatar
fklentz
The proper way to adjust them is via the drums. You'll need to jack up the rear end and remove the rear wheels. If you look at the rear discs you'll notice a rubber plug on the drum section of the disc. The ebrake has a set of brake shoes that adjust the same way conventional drum brakes do. If you take the rubber plugs off and then rotate the disc while looking thru the hole you'll see a star wheel that you can adjust with a screw driver. Be sure to not over tighten them.
Old Jul 14, 2007 | 09:51 AM
RedlineZdude
alright sweet, thanks man
pslamp32
Feb 8, 2017 09:07 AM
onefastdoc
Jan 22, 2003 04:25 PM
Scanman
Nov 25, 2002 10:56 AM
ares
Oct 30, 2002 02:49 PM
