Eibach springs installed!!
Old Apr 18, 2008 | 01:15 PM
  #41
jstineiii's Avatar
jstineiii
a little more -- eibach says that it will be ok and not to worry about camber arms until you hit 1.5 inch drop, but I just don't want to chew up my tires in 10,000 miles instead of 30 or 40,000. thanx
Old Apr 18, 2008 | 01:35 PM
  #42
sk26dett's Avatar
sk26dett
If your running the sportline kit you "should" get a camber kit in the rear, the front isn't as necessary. Without it your tires will wear pretty quick. The fronts aren't too bad. i would say i lost about 2-3k miles of life with my sportlines on (on oem re040's that is).
Old Apr 18, 2008 | 01:53 PM
  #43
jstineiii's Avatar
jstineiii
thank you very much for the quick reply. I am only getting the pro-kit. Sorry, I should have mentioned that. So it looks like I'll be OK. thanx again,
Old Apr 18, 2008 | 02:01 PM
  #44
sk26dett's Avatar
sk26dett
yea, most people are able to get within oem specs with the prokit, some sit lower that others and need a camber kit.
Also about hop up racing, i never knew about their sh!tty return policy, but i've ordered a couple of items from them and never had a problem, always got the parts quick. Had the springs already been shipped or something?
Old Apr 18, 2008 | 04:25 PM
  #45
ErinFaulk's Avatar
ErinFaulk
Originally Posted by jstineiii
I am getting ready to put on the eibach springs. Does anybody know if I will need to get camber kits. And it so, will I need just rear or front or both. I ordered the eibachs then heard that maybe I would need camber kits which will cost me an extra 1000 bucks for both and installation. I tried to return them to Hop Up racing, but Hop Ups policy is that if it has been longer than 4 days!!!!!! they won't take anything back. I wanted to buy the hotchkis from them instead, but it had been about 7 or 8 days and they would not bend. I will never buy anything from them again - something you guys might want to consider - very poor policy - I never heard of a (4) day return policy ---- anyway -- back to the first question - does anybody know if I will need camber arms. thanx
I had to get a camber kit for the rears, I am running Eibach Sportlines
Old Apr 18, 2008 | 06:24 PM
  #46
jstineiii's Avatar
jstineiii
thanx again for your help. Yes the springs had been shipped and received, but the shop only had them for maybe one week and I even called and explained the situation and that I was willing to purchase the hotchkis from them. They still wouldn't budge stating that you only have four days to return them. I told them that negative blogs will cost them a lot more money than making the exchange which of course I would have even paid the restocking fee. But Whatever!!!! I will not buy from them anymore.
Anyhow - I don't want to have to e-bay the eibach's so I am going to go ahead with the install, but I just hope that they will be OK, b/c working with a budget and don't want to have to put out for the camber arms right now.
Thanx again. Will probably be off line until Monday.
Old Apr 18, 2008 | 07:14 PM
  #47
jstineiii's Avatar
jstineiii
just wanted to add on my mods: 05 base model, B&M short shift kit, Injen ses true dual exhaust, high flow cats, DC ceramic headers, unichip, Altered atmosphere reflash, Procharger w/ intercooler with 9 lb. pulley, MD 5/16 plenum spacer, 440 jets, 35%tint, Eclipse sound system with navigation, 15 lb flywheel, stage II clutch, super lightweight Kossie wheels (10 spoke with 452's -- 275 rear, 245 front, carbon intake, hotchkis antisway, and more to come. Going with engine dampening kit, jwt oil pan spacer, and the Eibach pro-kit. After that - lightweight battery repositioned to the rear of vehicle. Right now 380 hp to the wheels.
Old May 19, 2008 | 04:46 PM
  #48
RON D.'s Avatar
RON D.
I'd also like to know PRO or SPORTLINES? CAMBER KIT?
Old May 21, 2008 | 09:58 AM
  #49
M3ownZ's Avatar
M3ownZ
Originally Posted by alving
Ride is still great!
Back from the dead yo!
Old May 24, 2008 | 11:45 AM
  #50
Mikey1231's Avatar
Mikey1231
nice drop! you most def convinced me to go with the pro kits.
Old May 24, 2008 | 06:32 PM
  #51
alving's Avatar
alving
Definitely the Eibach Pro springs, not the sportlines. I beleive the sportlines offer a lower height but softer spring rate?
And no, I did not have a camber kit installed.
Old May 24, 2008 | 08:14 PM
  #52
Chad68's Avatar
Chad68
edit never mind LOL
Old May 24, 2008 | 08:32 PM
  #53
Phantom Menace's Avatar
Phantom Menace
I've had my Pro-Kits on about a year now and they've settle a bit lower than when I first installed them but the ride has maintained the same--in terms of handling and quality. I also put in Eibach's rear Camber kits with the springs and had them aligned right after the install, and 3 months after. Both alignments were within OEM specs with room to spare.
When/if my shocks wear out, I'm thinking Koni. Anyone here use Pro-Kit Springs with Koni Yellows?
Old Jan 11, 2009 | 06:33 AM
  #54
350ZnFuture's Avatar
350ZnFuture
found answer
Old Jul 31, 2010 | 06:28 PM
  #55
MOD5's Avatar
MOD5
Just ordered mine. Little concerned though. Was there a noticeable improvement in handling over stock? Ordered new sways so that should help too.
