OEM Brembo bleeder repair
Old Jul 3, 2007 | 11:14 PM
1cockyZ's Avatar
1cockyZ
Default OEM Brembo bleeder repair
This is probably one of the suckiest things that has ever happened car wise I had never had to touch my bleeders on my 03' track. I bought the car new. So in preparation for a track day I am installing ss lines and flushing the system with ate blue. I go to losen the front right outside bleeder and it came out with the threads from the caliper on the bleeder. So is there anywhere that can repair this.
Old Jul 6, 2007 | 09:52 PM
adrianko43's Avatar
adrianko43
Try posting in the autox/road section for some replies.
Old Jul 7, 2007 | 12:29 PM
ht4's Avatar
ht4
See the link below. It's a PITA and may never look exactly the same (it will look close), but its the best solution short of buying a new caliper. You may want to try some sort of thread insert first, but you risk the bleeder screw not seating perfectly... and why risk that?
http://www.truechoice.com/prodinfo.a...=BLEEDER%20KIT
Old Jul 7, 2007 | 12:30 PM
ht4's Avatar
ht4
Why, it has nothing to do with autox?
Old Jul 8, 2007 | 10:09 PM
1cockyZ's Avatar
1cockyZ
I already bought a new caliper but I was going to fix this one for a spare. Local machine shop wouldn't touch it.
Old Jul 9, 2007 | 12:50 AM
Michla22's Avatar
Michla22
Doesn't surprise me - most places are not going to touch it due to liability - if it fails and causes the brake system to fail they would be liable for the work they did.
Try this: http://www.ersco-mi.com/helicoil1.html
Old Jul 9, 2007 | 06:03 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Good info/options in this thread. One of my Brembo bleeders doesnt bleed anymore. Its fine right now, but something I'll want to look into in the future.
Old Jul 9, 2007 | 06:44 AM
ht4's Avatar
ht4
The thread insert might work very well, but there are a couple possible problems that occur to me with using them on this application:
1- the install has to be PERFECT for the bleeder screw to seat correctly.
2- Because you lose the perfect machined fit, bleeding will ALWAYS be a two man job becuase you will suck so much air around the bleeder screw.
3- It would be very difficult not to damage the seat when drilling and tapping the bleeder hole.
Further, who wants to take the chance in such a critical place?
Old Jul 9, 2007 | 09:09 PM
1cockyZ's Avatar
1cockyZ
The only place that could do this competently would probably be the actual place that has the jig that holds the caliper to be drilled in the first place. I don't think brembo or whoever actually makes it is going to do it. The whole perfect seating is the conundrum.
Old Jul 10, 2007 | 08:10 AM
ht4's Avatar
ht4
Exactly... that's why a bleeder repair kit is the best way to go IMO. It completely replaces the bleeder screw and seat with parts that were machined to fit together.
350z82
Oct 1, 2015 06:25 PM
