Spring install, top nut difficulties
Old Jul 23, 2007 | 08:34 PM
Row2K's Avatar
Row2K
Default Spring install, top nut difficulties
I'm having a lot of trouble getting the top nut of the strut, so I can swap springs. Does anyone have any suggestions to make this easier. I did compress the spring before I attempted it btw, but still no luck
Old Jul 23, 2007 | 09:07 PM
Ztalker's Avatar
Ztalker
you need to compress the spring and release all the tension first. An impact wrench is necessary to remove the top nut.
Old Jul 23, 2007 | 09:28 PM
Mazinger Z's Avatar
Mazinger Z
Impact gun would be nice but me and a buddy got it off by pure strength! Yea compressing the spring would be helpful.
Old Jul 24, 2007 | 04:14 AM
Lawn Dart's Avatar
Lawn Dart
Impact gun? I don't think that will work because you need to hold the center stud with vise grips. It shouldn't be too tight, because the torque is only 40-47 ft-lbs. I used an offset wrench like this.
Old Jul 24, 2007 | 04:22 AM
RedBullRR's Avatar
RedBullRR
Use a Vise Grip clamp it to the rod of the Strut. Hold it while you take the nut off. When trying to take the nut off the strut just spins freely. If you hold the rod with a Vise Grip comes rite out. This is how I have done all my drops.
Old Jul 24, 2007 | 06:59 PM
Row2K's Avatar
Row2K
gotcha, i figured I would prob need the offset wrench, but just wanted to be sure thats the right way to go about it...better ask then strip a nut. Ha
Thanks,
Mario
Old Jul 25, 2007 | 01:24 AM
mthreat's Avatar
mthreat
Whatever you do, please read this:
Do not try to loosen the bolt without the spring compressed. If you do, the top part can shoot up with a lot of force and seriously hurt you (put out your eye, whatever), or someone else.
I hadn't even thought about this, but when I brought my spring assembly by sears and asked the tech to loosen it for me (which maybe you can do too!), he was real careful about this.
samansharif
Sep 25, 2015 12:31 PM
