Caliper Relocation
Old Aug 7, 2007 | 09:34 AM
GA_VQ's Avatar
GA_VQ
Default Caliper Relocation
I have heard tell of a company producing brackets that relocate the base calipers to allow for usage of Track sized rotors. They include all four brackets and Track sized rotors for something like $600. I did a search but came up empty. Does anyone know who does this? Also, what are your opinions on the modification?
Old Aug 7, 2007 | 01:43 PM
The_VQ's Avatar
The_VQ
I've seen some kits for Hondas, but never for a Z, I might be wrong but with larger brake rotors brakes should not be that vulnerable to fading - the heat will be desipated faster. Will it affect the brakes effectiveness? Don't think so.
You could try to make these brackets by yourself, this ain't no rocket science - find yourself a shop with a CNC machine, buy the rotors, measure everything properly and get them made.
This is a reference photo I've found for you:
This is a 330mm rear rotors upgrade for RX-7, as you can see the brackets are pretty simple.
Old Aug 7, 2007 | 02:20 PM
GA_VQ's Avatar
GA_VQ
I'm certain someone makes a front and rear kit. I found a front kit, but I can't seem to find the "total package".
Old Aug 7, 2007 | 02:49 PM
umzzz's Avatar
umzzz
Cwest Army
is it racing brake?
http://www.racingbrake.com/350Z_non_...2070-141-0.htm
i believe it relocates the stock caliper further away to fit larger rotors
Old Aug 7, 2007 | 03:40 PM
VIZAGE's Avatar
VIZAGE
That's pretty nice. I'd like to here more opinions on what people think about these? It's something that I wouldn't mine giving it a thought.
Old Aug 7, 2007 | 03:45 PM
redlude97's Avatar
redlude97
IMO, its a poor solution that can cause brake performance to worsen due to shifts in brake bias.
Old Aug 7, 2007 | 04:47 PM
THE TECH's Avatar
THE TECH
+1
Not something I would put on my car.
Old Aug 8, 2007 | 12:19 PM
GA_VQ's Avatar
GA_VQ
http://www.racingbrake.com/350Z_non_...2002-211-0.htm
Here's the rears. I dunno why I couldn't find these the yesterday.
Old Aug 8, 2007 | 12:29 PM
GA_VQ's Avatar
GA_VQ
http://www.racingbrake.com/350Z_s/2432.htm
Should've put up this one. I think the bias would be jacked because both the front and rear rotors are 13". Also the price of the two cheapest kits combined is $1039.83 not including pads or shipping. I have definitely changed my mind.
Old Aug 8, 2007 | 04:46 PM
rcdash's Avatar
rcdash
I think this is a great value and probably the single most effective mod to eliminate fade using the stock calipers. Brake bias will obviously change if you only do the fronts, but I doubt it will diminish braking performance...
sales@czp
Sep 23, 2019 03:30 PM
ZXoltan
Brakes
19
Nov 25, 2015 04:21 AM
seagrasser
Oct 11, 2015 03:27 PM
350Shadow
Sep 22, 2015 08:30 AM
