whats a good spring for tokico d spec?
Old Aug 12, 2007 | 02:02 PM
jOeL350z's Avatar
jOeL350z
Default whats a good spring for tokico d spec?
i was actually thinking of tein h techs. Im not sure on how the ride quality is going to be. I just one something just as good as stock. If anything, i want the ride to feel like stock.
Thanks guys
Old Aug 12, 2007 | 03:54 PM
HyperSprite's Avatar
HyperSprite
Mad Scientist
You don't say if you want it any lower or what year you have.
Check out GSedan35's post in this thread
https://my350z.com/forum/brakes-and-suspension/154233-spring-rate-database.html
It shows the stock rates and the rates and drops for many aftermarket springs. You will find most are not much stiffer than stock and some are softer.
The D-Specs will work fine with the stock springs if you want to keep the hight and the ride quality.
Chris
Old Aug 12, 2007 | 06:53 PM
synth19's Avatar
synth19
I'm running the dspecs with stech's. Great combo IMO.
Old Aug 12, 2007 | 07:01 PM
Gsedan35's Avatar
Gsedan35
Originally Posted by jOeL350z
i was actually thinking of tein h techs. Im not sure on how the ride quality is going to be. I just want something just as good as stock. If anything, i want the ride to feel like stock.
Thanks guys
D-specs are really good shocks, they will be fine with H-techs, though you may prefer something with a bit more then .3"/.2" drop that they'll give you, I dunno.
Old Aug 12, 2007 | 08:20 PM
Blazemaster's Avatar
Blazemaster
according to the spec sheet, the tokico springs are a good choice also, but they drop a bit more than what you want. The spring rates are only slightly stiffer than stock.
Old Aug 12, 2007 | 11:31 PM
black06z's Avatar
black06z
Don't get the H.tech. You will be dramatically disappointed in the drop. Get the S.Tech if anything to match the D-Spec.
EnjukuRacing
Sep 30, 2015 06:55 AM
