noise-after changing rotor pads and service brembo
Old Aug 28, 2007 | 01:26 AM
silviakoko's Avatar
silviakoko
Default noise-after changing rotor pads and service brembo
My ride make a fade noise after replacing 4 rotors and the rear brake pads , it sounds like fade squeal, noise that normally occur when the metal indicator touches the rotor but all my brake pads are fine.Only happen after changing the rotors and brake pads, by the way my front brembo caliper has been serviced.
Any opinion? Had sent the car to the mechanic more than 3 times and they can't figure out.
Old Sep 2, 2007 | 06:41 PM
silviakoko's Avatar
silviakoko
help please
Old Sep 2, 2007 | 07:15 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
did you use the shims up front? use anti squeal compound?
the brembos are noisy calipers to begin with
Old Sep 2, 2007 | 07:21 PM
silviakoko's Avatar
silviakoko
sorry the noise occur even when i am not using the brake.
Old Sep 2, 2007 | 07:28 PM
Z1 Performance
Former Sponsor
then your installer needs to completely go over the installation again
Old Sep 3, 2007 | 08:35 AM
Kolia's Avatar
Kolia
Any chances the wear indicators are mounted on the outside of the caliper ? They might be rubbing against the rotor's hat...
