Cadillac CTS-V brembo in 06 350z
Old Sep 13, 2007 | 10:07 AM
raihansdg's Avatar
raihansdg
Exclamation Cadillac CTS-V brembo in 06 350z
I was wondering if i could upgrade the brakes(non brembo) of my 06 350z to these brembo brakes...
These brakes are from an 06 CTS-V. Both front and rear calipers are 4 piston.
I am worried about the fact that, since they use 14" rotars and has 4 pistons in the rear calipers, would it effect the handling of the car at high speeds??
Comments are highly appreciated, please let me know asap!!!
Old Sep 13, 2007 | 10:10 AM
Motormouth's Avatar
Motormouth
do we have the same master cylinder specs as they do?
Old Sep 13, 2007 | 10:11 AM
InZomniac's Avatar
InZomniac
Short answer= No they will not work
raihansdg's Avatar
raihansdg
Yes!!!
raihansdg's Avatar
raihansdg
WHY not!!!!!!!!!!!?
Old Sep 13, 2007 | 10:13 AM
Motormouth's Avatar
Motormouth
wait, we use the same brake master cylinder as the CTS spec V?
same F/B proportioning?
Old Sep 13, 2007 | 10:17 AM
raihansdg's Avatar
raihansdg
damnn... not for V , i dont know that......
Old Sep 13, 2007 | 10:20 AM
Motormouth's Avatar
Motormouth
I would check out Stoptech's website... they have some technical resource information that might help you understand the problems you will encounter trying to swap over a OEM setup not setup for our specific car..
raihansdg's Avatar
raihansdg
@ motormouth
Ok so if the MASTER cylinder spec are not the same, its not worth getting these brakes?
Old Sep 13, 2007 | 01:14 PM
simonfencer's Avatar
simonfencer
there are quite a few factors involved in the relationship of brake components.
Piston diameter in the calipers, piston diameter in the master cylinder, brake pedal length (it effects the amount of effort required), proportioning valve settings.
You would probably be able to get them to work, since mechanically the parts work in the same manner. Whether or not you would get acceptable results is another question.
Old Sep 13, 2007 | 02:09 PM
Motormouth's Avatar
Motormouth
^ about everything I was about to type.
if you transfer over the whole shebang and get a brake valve proportiner (found in race cars) you could get it to work.
but then you have to figure out if the pedal travel is the same, then modify your pedal assembly, etc, etc, etc, etc,
NOT A GOOD IDEA. I've thought about it as well. the upgrade kits are designed to be within ratio of the stock kit in terms of the piston size and f/r balance and to work with the master cylinder.
you will get terrible pedal feel, longer stopping distances, possible wheel lockup, etc.
Old Sep 13, 2007 | 02:21 PM
Lawn Dart's Avatar
Lawn Dart
Sounds like a lot of hassle for something that may not work that great.
Old Sep 13, 2007 | 02:25 PM
raihansdg's Avatar
raihansdg
ohh well anyways, thanks guys... i was getting them for 421 shipped!!
cants beat that price..... thanks for all ur help guys
Old Sep 15, 2007 | 08:29 AM
rkd350z's Avatar
rkd350z
G/L to you and hope to see that on your car~!!
Old Sep 15, 2007 | 08:35 AM
Z04's Avatar
Z04
+1
issyz
Jul 2, 2017 03:04 PM
wanderingstuden
Jan 28, 2016 07:03 PM
Justin100
Nov 29, 2015 03:58 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
codek
Sep 28, 2015 03:03 AM
