Nismo S-Tune springs on stock shocks?
Old Sep 28, 2007 | 05:49 AM
Hot Cu's Avatar
Hot Cu
SlammednFlush
Default Nismo S-Tune springs on stock shocks?
Can this be done? Do anyone just sell the Nismo S-Tune springs by themselves? Or is the closest to the Nismo S-Tune very subtle drop the RS-R springs? Does anyone have pics of before and after of this RS-R drop on stock shocks?
Old Sep 28, 2007 | 06:00 AM
drivesolo's Avatar
drivesolo
I had the RS-R's Ti3000 on Koni yellows on my '03. They felt pretty good, stiff enough to give better performance but still soft enough that the change was not noticable at all when driving on the streets. I looked into getting just the S-Tune spring, but I was not able to find them anywhere. They can be used on the OEM shocks although it's probably not good choice since they have a considerably higher rate than the OEM springs, noticeably more than the RS-R's I'm told. You would need something w/ adjustable valving to balance the dampener to the spring. Or just get the S-Tune coilovers.
F/R in kg/mm (x56 for lbs/in):
OEM - Revised : 5.7 / 7.7
RS-R: 6.2 / 7.5
Nismo S-Tune: 8.1 / 8.9
I'm considering getting the Nismo S-Tune for my '07 since I want the performance but not the really harsh ride on the street.
Old Sep 28, 2007 | 08:28 PM
Gsedan35's Avatar
Gsedan35
That would be a extreamly bad idea, oem shocks will not have the valving capacity in reserve to handle that much of a increase in spring rates, ride and drive quality will take too big of a hit. The closest spring setup in spec and drop height will be the Tein S-techs.
RSR 350Z linear springs .6”/.6”
Spring rates in LBS 345/417
Tein S-tech 350Z springs .7“.6“ (fronts are slightly progressive, rears are linear)
Spring rates in LBS 386/402 (estimated front intial rate is 327lbs)
Nismo S-tune (twin tube construction, uses progressive springs)
350Z .8"/.8" drop
Spring rates 448/504
nanotech
Oct 2, 2015 05:02 AM
