NEED HELP PLEASE: installing OEM BREMBOS
Old Sep 28, 2007 | 09:17 PM
Drock's Avatar
Drock
Default NEED HELP PLEASE: installing OEM BREMBOS
hi..
ok after much searching... ive finally found that the offets and dimensions on the anniversary OEM 18's are. which im using as a point of reference.
F- 18x8 30 offset
R- 18x8.5 33offset
I finally found a used complete set of OEM brembos from a 2004 G35.
I have a set of 19" HRE's on my 2005 Z
F- 19x9.5 24 offset
R- 19x10.5 34 offet
by eye.. the front currently has a good amount of caliper/rim space.. there is definitely a good gap. even more in the rear.. so logically I think the Brembos should fit..
using the OEM 18's with a 30 offset as a referance.. im well below that with a 24 offset.! in the front
my friend is a Nissan Mechanic and has installed other parts on my z.. he says the rear is not an issue.. if theres a problem it will be up front..
currenlty im waiting for those freaking calliper bolts... 2 per caliper.. that my set did not come with.. so Im stressing with anxiety till they come in.. and if the calipers will fit..! I wont even biggen to imaging how pissed I will be if they dont..! however I read here.. that the front non-brembo bolts can be used on the brembo calipers.. however the rear must be the brembo bolts? is that true?
if someone can provide some feedback it is SUPER appreciated..!
thanks
Tony..
Old Sep 28, 2007 | 09:21 PM
SuperBlack350z's Avatar
SuperBlack350z
they'll fit.
Old Sep 28, 2007 | 10:05 PM
Drock's Avatar
Drock
Short and sweet.. I like that... thanks..
Im assuming you mean the brembo kit..
anyone have any idea of the non-brembo caliper bolts fit the brembo calipers..?
Old Sep 30, 2007 | 10:17 AM
Drock's Avatar
Drock
hi,
any second opinions.. please? if the calipers will fit..
and its been confirmed that the 2 non-brembo caliper bolts CANNOT fit with the brembo caliper
thanks
Tony
Old Sep 30, 2007 | 10:52 AM
GTM's Avatar
GTM
Vendor - Former Vendor
The calipers WILL fit...
You NEED to use the Brembo bolts ( if used make sure they give you the bolts )
Good luck!
-George
GT Motorsports
Old Oct 3, 2007 | 06:50 PM
raycs7's Avatar
raycs7
The rear bolts are different for Brembos.
Hope you got the lines too.
Old Oct 6, 2007 | 08:03 AM
Drock's Avatar
Drock
hi,
ya I have the break lines..
im still waiting for the freaking bolts... I have a friend who specializes in all Nissan OEM and aftermarket parts... if there is someone who will get them the fastest it would be him... but these specific bolts arent exactly a regular order that Nissan gets.. so we are approaching 3 weeks that im waiting now.!
I just hope the freaking front calipers fit..! all this waiting and anxiety.!
if they dont fit.. i'll have to use spacers.. on the front.. but then id get them for the back too cause I would not want it to be uneven..
and ive heard Spacers cause vibrations... at higher speeds? is this true... cause from ive read here.. lots of people are using spacers..
anyone have some opinions on that..?
thanks
Tony
Old Oct 6, 2007 | 08:06 AM
VN_350z's Avatar
VN_350z
Wow, you have all Nissan friends. cool.
is Carlos Ghosn your friend too?
Old Oct 6, 2007 | 08:53 AM
Drock's Avatar
Drock
sorry man.. I dont quite get your comment..?
One of my friend's is a mechanic at a Nissan dealer in my area, and I know another guy who orders Nissan parts..
who the heck is Carlos Ghosn?
and what does that have to do with asking if SPACERS cause vibrations..?
Old Oct 6, 2007 | 08:57 AM
mario23's Avatar
mario23
The rear Brembo bolts are the only ones you need.
Those offsets should not be a problem at all.
Old Oct 6, 2007 | 09:45 AM
VN_350z's Avatar
VN_350z
look up for Carlos Ghosn.
Old Oct 6, 2007 | 10:16 AM
raycs7's Avatar
raycs7
I ordered mine over the counter and it arrived in 2 days.
Installed on my touring roadster with 07 gt wheels with no problems and no help needed from Carlos.
Old Oct 9, 2007 | 06:03 PM
Drock's Avatar
Drock
the Caliper bolts have finally come in..! its about time.. they were on back order..!
so its do or die now.. to see if the brembos will fit..!
going to get them installed on thursday..!
Old Oct 11, 2007 | 12:43 PM
z-u-later's Avatar
z-u-later
For someone who claims he has Nissan friends, it sure takes them a long time to get parts for you.
Old Oct 16, 2007 | 01:00 PM
Drock's Avatar
Drock
whats the use of a wise guy comment like that..! the freaking bolts were on back order..! it has nothing to do with them.. I have a friend who is a nissan mechanic at a dealer in my area.. and another guy that I order parts from and who happens to kow alot about nissan cars..etc..
ANYWAYS!
good news..! the calipers in the front fit just perfect.. with a few milimeters of caliper space, literally..! but thats ok.. I was hoping for a nice flush look..! Im so glad I did not have to use spacers..!
NOW ONCE AT FOR ALL.....: THE 2 NON-BREMBO CALIPER BOLTS FIT THE BREMBO CALIPER. THEY ARE THE EXACT SAME BOLTS. I SAW WITH MY OWN EYES!!!
THE REAR ARE NOT THE SAME. THEREFORE YOU MUST HAVE THE BREMBO REAR BOLTS.!
here's a nice picture of my Z at SCP8 show ( Sport compact performance), just after I got the Brembos installed. its the biggest car show in Canada. it is held at the Olympic Stadium in Montreal every year..!
Old Oct 16, 2007 | 01:40 PM
raycs7's Avatar
raycs7
Everyone said only the REAR bolts were required.
Now you need a 17 spare wheel that works in front.
Old Oct 16, 2007 | 07:08 PM
Drock's Avatar
Drock
hi,
nah.. I dont drive the car in the winter.. its stored away..
I was given mutiple opinions about the bolts.. some said you only need the rear, some said you only need the front, and other said you need all of them.
so to be safe.. I ordered all 8..
Old Oct 17, 2007 | 02:59 AM
raycs7's Avatar
raycs7
What I meant was ...Your current spare is no good on the front. It will touch the caliper.
Old Oct 17, 2007 | 03:18 AM
SuperBlack350z
told you it would fit. Congrats you got everything working.
You never needed the caliper bolts for the front, it's only for the rear.
Old Nov 17, 2008 | 04:37 PM
kRuSty_kiD's Avatar
kRuSty_kiD
sorry im really confused. i have brembo and want to go non brembo. so i need to buy rear bolts that fits NON BREMBO and in the front i can use the brembo bolts i have now to fit the NON brembo brakes? thanks in advance.
