TEIN Springs
Old May 31, 2003 | 07:16 AM
Gsedan35's Avatar
Gsedan35
Originally posted by Stone Z
Not sure if they're out yet, but H&R springs usually have more of an aggressive drop than the Eibach's do.
And more sensible logic behind their spring rates as well. Even though H&R holds their spring rate info as dear as coke holds dears the coke classic formula. I won't whine about Eibach's 350Z spring rates, but the G35 sedan rates are not something I'd ever use. (yes I drive a sedan, not a coupe but love the FM )
Old May 31, 2003 | 07:32 AM
Gsedan35's Avatar
Gsedan35
Originally posted by EnthuZ
Thanks Jason.
I love the line "funner to drive"
OK, next ?...........OEM spring rates?
I'm pressing for the same info. Absolutely have to have the stock spring rate info as a base line to judge any lowering spring rate info. Yes you can make some judgement's based on how much a given vehicle weigh's. But it's not the same as knowing where your truely starting from and what logic was applied from the start. Like front to rear spring rate balance (or in-balance).
I've been meaning to call progress grounp or Ground-control and see if I can send one of them a set of stock 350Z springs I have to put on a spring dyno (if that's what you call the machine that measure's spring rates) to get the stock spring rate info.
If anyone has a better idea of where to send a set of springs to be tested to find out spring rates, let me know. Maybe I should do a post on www.sccaforums.com and the grassroots motorsports forum as well.
Old May 31, 2003 | 02:38 PM
EnthuZ's Avatar
EnthuZ
Here in Chicago, there used to be a "Roundy-Round" shop that would rate springs for a nominal fee. I'm sure you have a few of them in CA. Try calling a few circle track shops....I'm sure you can find one close to you that can do it.
Make sure they check them at 1", 2" & 3" compression.
Good luck! WE NEED A BASELINE!
Old Jun 1, 2003 | 01:15 AM
ray_7's Avatar
ray_7
Originally posted by VQracer
failsaf3, you have TEIN Type Flex coilovers, so your drop can vary. I believe this post is talking about TEIN S.Tech springs.
Just clarifying.
Victor
Just checked again, it's actually a TEIN HIGH TECH springs.
The installer claims it'll have a 1" drop, but I don't think its that much up to this day. Almost 2 week installed...
Old Jun 8, 2004 | 02:23 AM
Zster's Avatar
Zster
Default Just lowered my Z with Tein S.tech
I bought a set of wheels a couple months ago... they are Racing hart CR multi-piece gunmetal 19x8.5 front and 19x10 rear... My freinds keep on telling to lower it... and i finally did! I was gonna use the Eibach Prokit, but a friend of mines recommended the Tein S.tech... With the S.tech springs i got about a finger and a half gap in the front and 2 to 3 fingers gap in the rear... i am new to this forum... can someone tell me if my springs are gonna settle any lower... today its the second day i had it on... thanks
Old Jun 8, 2004 | 07:43 AM
Trent@MVP's Avatar
Trent@MVP
Default Re: Just lowered my Z with Tein S.tech
To accurately know how much they have dropped, you would have needed to measure the height before the springs and then after to see if you are getting the advertised drop that Tein is saying will happen when the springs are installed. Measure from the center of the wheel to the edge of the fender. Maybe someone can do that for you if they have the same size wheels and tires and get you that measurement. Then take your measurement and see if they have dropped as much as Tein says it should. The 2nd day is not long enough for them to settle just yet. Give it at least a week and a half to two weeks before worrying about the height.
Old Jun 8, 2004 | 10:56 AM
aaaaa's Avatar
aaaaa
i wanna see pic with s-tech drop
Old Jun 8, 2004 | 12:01 PM
zxsaint's Avatar
zxsaint
Fairlady Stalker
S-Techs on my car approx 2 weeks to settle.
Old Jun 8, 2004 | 03:16 PM
Zster's Avatar
Zster
k thanks for the feed back guys.... i will upload some pictures tonight
Old Jun 10, 2004 | 03:37 PM
Zster's Avatar
Zster
here are some pics of my Z with tein s.tech on..
Old Jun 10, 2004 | 03:39 PM
Zster's Avatar
Zster
another angle
Old Jun 10, 2004 | 03:42 PM
Zster's Avatar
Zster
rear view
Old Jun 10, 2004 | 03:50 PM
Zster's Avatar
Zster
rear
Old Jul 19, 2004 | 04:27 PM
Vivid Racing's Avatar
Vivid Racing
Vivid Racing
Those are some pretty sweet rims. I have the same color car and i'm still trying to decide what rims to get. I would go with coil overs though, that way you can get the perfect drop. But those S techs look pretty good.
Old Jul 19, 2004 | 11:58 PM
Zster's Avatar
Zster
True... i am thinking of installing some Tein type Flex soon.. When i parked my car next to my freinds lowered 03 NSX... my car didn't look lowered at all!!! I also like the volk racing TE37 limited edition with gunmetal spokes and polished lip... maybe you can look into that also!!!
Old Jul 26, 2004 | 01:00 AM
NVS_350Z's Avatar
NVS_350Z
hows the ride? The stock ride is a bit bouncy, doesnt bother me but the passengers all get headaches.
Im interested in a 1.2-1.5 drop
Old Jul 26, 2004 | 06:19 AM
Zster's Avatar
Zster
i suggest u go with eibach pro kit, u will achieve the 1.2 to 1.5 drop... the tein s.tech rides better over stock... but i am not really sure about the eibach... i been on one with eibach installed, it felt pretty comfortable...
Rowlett
Misc.
Oct 2, 2015 10:38 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
