Cobb Tuning Spring/Sway Review.
Old Oct 1, 2007 | 02:40 PM
knucklez's Avatar
knucklez
Default Cobb Tuning Spring/Sway Review.
Hello, my name is Paul and I am currently a owner of a 2006 Nissan 350z. This past week, I was lucky enough to be to test out the Cobb Sport Springs and the Cobb Anti Sway Bars. This sponsorship was possible due to Andy@Performance Nissan (I thank him greatly for getting me sponsored). Before the suspension upgrades, my car was rolling on everything stock besides rims, tires, and body kit. After a weeks worth of driving, I can totally feel the difference compared to the stock suspension.
First off, the springs give the car a very aggressive look. The 3/4" front drop and the 15/16" rear drop was perfect for my huge lip body kit, it was a perfect match for the JP Type N kit. The ride feels as if I have more control of the road, definitely because of how low it sits. The ride isn't bouncy or bumpy at all, it is a very smooth ride with much better handling .
The sway bars made a HUGE difference on the cars suspension. Right off the bat when I drove home, I knew that the handling was stiffer and more stable. Hitting sharp turns and corners stiffened up a lot, making the car extremely aggressive with handling.
Before Picture:
After Picture:
Overall, I am pleased with the results of the Cobb products. Test driving a stock 350z then driving my Cobb upgraded 350z is a huge difference. I would recommend forum members and my friends to try out Cobb Springs/Sway Bars.!
Here are some extra pictures, if you want.
Old Oct 1, 2007 | 02:54 PM
Benzoboi's Avatar
Benzoboi
maybe it's cause of the shadows but the drop doesn't look that "low"???
Looks good nonetheless!!!
Old Oct 1, 2007 | 03:00 PM
Andy@Performance's Avatar
Andy@Performance
Performance Nissan
The drop is very mild but once the springs settle in, it will definitely go lower a bit more.
Old Oct 1, 2007 | 03:50 PM
gimpster621's Avatar
gimpster621
looks great paul. now track that thing =D
Old Oct 1, 2007 | 03:54 PM
gambino's Avatar
gambino
I have the exact same suspension on my 07 and love it! I have had it on now for 5 or 6 weeks and the car does settle down a bit lower. My front tires are almost tucked and it looks amazing!
Old Oct 1, 2007 | 03:58 PM
Benzoboi's Avatar
Benzoboi
Nice I could tell that there is a visible drop by the front lip of the car...it's ALOT closer to the ground...and I'm sure it needs to settle in also...look forward to seeyin it after it settles!!!
Old Oct 1, 2007 | 04:16 PM
gambino's Avatar
gambino
you can see the difference here too.
Mine before the drop:
After:
I need to get a picture of the car now too, but it is stormy out. I will try anyway
Old Oct 3, 2007 | 07:14 AM
trodis's Avatar
trodis
how much for parts and setup?
--looks like no need for camber kit?
Old Oct 3, 2007 | 01:09 PM
nearly zer0's Avatar
nearly zer0
What did you get the camber back to after the springs?
Old Oct 3, 2007 | 01:13 PM
knucklez's Avatar
knucklez
http://cobbtuning.com/products/?id=3477
Installation prices vary from shop to shop.
Old Oct 21, 2007 | 05:09 AM
PhiSig's Avatar
PhiSig
Wheel Whore
how does this compare to the Hotchkis spring/sway kit?
Old Jan 29, 2008 | 10:17 PM
bluezup's Avatar
bluezup
+1 i wanna hear this one.
Old Jan 30, 2008 | 03:56 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
the Hotchkis and Cobb sways are the same thing
the Cobb springs are stiffer than Hotchkis, since Hotchkis was designed around pre 04.5 cars and Cobb was designed on a later model (which have different struts)
Old Jan 30, 2008 | 06:42 AM
bluezup's Avatar
bluezup
iv been looking at the hotchkis for a while now up untill a few days ago when i started reading about Cobb, for my 05 base, daily driving car. would it be better to stick with my first pick the hotchkis? would it be the same/cheaper if i get the exedy clutch and fidanza flywheel?
Old Jan 30, 2008 | 06:52 AM
nismo_nate's Avatar
nismo_nate
with that drop, would it scrape the front with i.e. speed bumps? i was thinking of getting these... (fyi stock everything)
Old Feb 1, 2009 | 04:54 PM
BIG Z's Avatar
BIG Z
I have an 06 - so do you think Cobb is a better bet? I would rather have the slightly bigger drop with the Cobb, but I keep reading stuff about how the Cobb are too big for their seats?? Do you know anything about being unable to install Cobb springs because of their size? Thanks.
Old Feb 1, 2009 | 06:09 PM
TheOtherRob's Avatar
TheOtherRob
I too heard something about the springs being too big for the seat... Any truth of this?
Old Feb 20, 2009 | 06:23 PM
ADMAN's Avatar
ADMAN
Originally Posted by TheOtherRob
Any truth of this?
Old Feb 20, 2009 | 06:35 PM
Nismospeed4life's Avatar
Nismospeed4life
No COBB tunning?
Old Feb 20, 2009 | 07:55 PM
Z1 Performance
Former Sponsor
I've got no experience with Cobb's springs on a Z, so I could not say
2ndchanceZ
Oct 26, 2015 08:03 PM
nanotech
Oct 2, 2015 05:02 AM
KOF
Tuning
Sep 30, 2015 04:09 AM
