Will GTspecs braces clear Greddy TT Evo exhaust.
Hi guys, I already searched but could not find answers.
Any one here using GTspecs braces with Greddy TT Evo exhaust on there roadster ? will I the braces clear the exhaust ?
i have the full underbody brace, and it clears fine w/ my evo2. lotsa room. i also got the lower tie bar which doesnt interfere with it either. id say your safe to go that route
i read that too, but i also heard theyd fit. i dont think the underside of the z is different between the 2? well they fit fine on the coupe. i dont see why they wont work on the zr, but for the coupe with the greddy setup, they fit just fine.
the full underbrace will scrape alot of things, especially if ur lowered. i scrape alot, and im only lowered an inch! take into consideration, the brace is only less than 3(?) inches off the ground
do you have a 4 point brace ?
Yes, I have the 4 point and lateral braces for my ZR. the only fittment issue was due to the Stage II fuel system's external pump and surge tank.
Also because I am running on solid motormounts and have the Greddy oversized Oil Pan, some modificaiton is necessary for the front brace. But if your running a stock engine... no need to worry.
--B
--B
