R34 GTR Brembos on a 350z ??
Old Oct 5, 2007 | 05:29 AM
skat's Avatar
skat
Default R34 GTR Brembos on a 350z ??
Hi Guys,
i know a guy who is selling his GOLD Brembo brakes from an R34 Skyline GTR. They look exactly the same as the brembos on a 350Z so i was wondering if they would fit on the 350Z. I've asked around and there seem to be mixed opinions regarding the size of the bolts on the two cars. Apparantly one of them has thicker bolts than the other (can't remember which one uses bigger). Is this true ? Would the brakes simply bolt on to a 350z ?
Sorry if this has been covered already but i have used the search feature and been through lots of pages of threads and also looked at each thread in the brakes & suspension section but couldn't find any info regarding this.
Any help would be greatly appreciated. Thanks in advance.
Old Oct 5, 2007 | 01:09 PM
Bahraini350Z's Avatar
Bahraini350Z
they are the same set... they should fit given that you get the whole brake kit of the R34's
Old Oct 5, 2007 | 04:48 PM
Zivman's Avatar
Zivman
Originally Posted by skat
Hi Guys,
They will not fit. no oem brembo will cross over to another application.
Old Oct 5, 2007 | 04:52 PM
JDMFairladyZ33's Avatar
JDMFairladyZ33
And this is based off of what?
Old Oct 5, 2007 | 05:03 PM
Zivman's Avatar
Zivman
my contact at brembo that I purchased my BBK from. The specs may match exactly, but they will not bolt on. they will require modified mounting brackets
Old Oct 5, 2007 | 05:14 PM
JDMFairladyZ33
I'm not questioning you. I'm talking about Bahraini350Z's post. Base on what he is saying it should work like plug and play with the complete kit. If that's the case then he needs to back it up with something before giving people bad advice.
Old Oct 5, 2007 | 05:21 PM
Zivman's Avatar
Zivman
I asked my guy at brembo about crossing applications with oem setups. He said no oem setup will cross over without modification to another application. At the very least, they have different mounting requirements
Old Oct 7, 2007 | 11:39 AM
Bahraini350Z
You just need to fabricate the rear disc cover as it will rubb. We have a number of R34s here and my mechanic checked one of them to have it fixed on my car before I found this totaled Z that I got my kit from. You may check the part numbers with nissan if u r hesitating.
issyz
Jul 2, 2017 03:04 PM
wanderingstuden
Jan 28, 2016 07:03 PM
Justin100
Nov 29, 2015 03:58 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
codek
Sep 28, 2015 03:03 AM
