Quick question regarding braking
Hey guys! Question for the mechanically-inclined among us.
When I'm braking at very slow speeds (usually approaching a stop), my steering wheel sometimes pulls to the left pretty hard. It's strong enough that if I wasn't holding the wheel, it would do an entire revolution before coming to a stop.
What's up with that? Uneven brake pad wear? Bad wheel alignment? It only happens about 15% of the time while braking at slow speeds, but the wheel always tends to want to turn counter-clockwise a bit easier while braking.
It hasn't bothered me enough to have looked at since it's easy to counter-steer, but I'm curious about the problem.
BTW, this is with a relatively new 2007 GT Z (3500 miles).
Thanks!
Thanks!
Does your car pull in any direction while just driving around? If so, then your alignment is most likely off. Although it's odd to be having alignment problems with such a new car.
+1 about the braks pads though, check those before anything.
actually i had this happen in my corvette. turned out that there was an air bubble in the brake line causing the one caliper to not grab. at least thats what i was told caused it.
i could be way off here.
I didn't think about air in just one side. When you brake, pump it and then try. Normally there will be the spongy delay from the air not really pushing the caliper in, but if you try and pump it it moves the air out of the caliper (for a moment) and if that is what is wrong it should brake true.
Or bring it in to a shop, that sounds dangerous.
350Z_Al
Oct 29, 2020 07:44 PM
