Cusco Upper arms question? Help!
Old Nov 10, 2007 | 02:00 PM
zYouLater's Avatar
zYouLater
Default Cusco Upper arms question? Help!
Any answers is appreciated. I have an 03 that I lowered 3/4 inch with Hotchkis springs and sways. Camber was real bad and I ruined two Toyo 19's. I have just installed Cusco front adjustable A arms, Tokico D specs and SPC rear adjustable arms.
I went and had an all wheel alignment and they set everything to factory specs. The rear looks good, but they said they could not set the front any different from the factory specs. Any thing else would be considered a custom setting and they could not do this? WTF? They did not even adjust my upper a arms to offset the fact that the car has been lowered.
I think this will be no help since I'm lowered 3'4 of an inch. What should my front camber be set at considering my set up?
Old Nov 11, 2007 | 05:51 AM
zYouLater's Avatar
zYouLater
Anybody have and suggestions on camber adjustment?
Front left is -1.44
Front right is -1.85
Wheels are 19's
Tires are front 245/35,rear 275/35
lowered 3/4 to 1 inch.
Tokico D specs, Hotchkis springs and sways
GOAL is to have a good reasonable tire wear on a daily driver. Track use minimal, perhaps once a year.
Old Nov 11, 2007 | 04:50 PM
UrbanTacticZ's Avatar
UrbanTacticZ
The Cusco camber arms are made to increase negative camber for track use or whatever your reason(s) may be.
Sorry!
Old Nov 11, 2007 | 10:13 PM
UrbanTacticZ
No one can answer how much camber you will get from the adjustments on your Cusco arm. The adjustments points are in milimeters and not a preset amount of degree(s). You have to also remember that there is a camber curve so the lower your car, the more negative camber you will have and thusly the 1 and only positive increment will not be the same if your car was higher.
If you want to get your back closer to spec, you can either buy some new arms or max positive your Cusco arms and raise the car up until you are at the desired camber level.
Hope that helps!
Old Nov 12, 2007 | 07:23 AM
DVFlyer's Avatar
DVFlyer
Speed of White
Interesting..... I was just about to post a similar question. I just bought Cusco A-arms with the hopes of bringing my lowered Z back closer to stock alignment to save tire wear.
Old Nov 12, 2007 | 07:59 PM
1nate7's Avatar
1nate7
Did you adjust the arms for full positive camber before installing? If not, it's pretty easy to change.
Old Nov 12, 2007 | 08:17 PM
UrbanTacticZ
Well that's not even the problem. In any case, you can easily adjust them while they are installed. The issue is that there is only 1 setting for positive camber adjustment while the others are for negative camber only.
Old Nov 12, 2007 | 08:19 PM
UrbanTacticZ
Also, are you really adverse to running the negative camber? It's not much at all and as long as your toe is in spec, your tires will not wear out quickly at all.
Contrary to popular belief, toe is what will shreds tires quickly, not camber.
Old Nov 12, 2007 | 08:27 PM
zYouLater's Avatar
zYouLater
I just adjusted it out one click, or hole and it made an improvment in camber. My friend has a magnetic camber gauge and it did put it closer to spec. Left side is -1.25 and right side is now -1.56. It only moved the arm out about 1/8 of an inch.
Old Nov 14, 2007 | 10:52 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
that means the shop you brought it to for an alignment didn't touch the front camber at all....not cool
Old Apr 23, 2016 | 05:46 PM
Gunkata's Avatar
Gunkata
bumping an oldie, sorry.. I just installed a set of these - how do you adjust them on your own for negative camber / or instruct an alignment shop in order to do so? a little strange that some only had 1.4ish of neg camber when stock range is 1.3? any ideas?
thanks in advance.
Old Apr 23, 2016 | 08:30 PM
terrasmak's Avatar
Have you looked at them, loosen 4 bolts , slide the adjuster , tighten 4 bolts
Old Apr 24, 2016 | 05:41 AM
Gunkata's Avatar
Gunkata
those are the 4 on top? got it
so an alignment shop who knows their stuff, esp one that does "racecars", should know how to align those , yes?
Old Apr 24, 2016 | 06:47 AM
jdmfetish's Avatar
jdmfetish
yes
Old Apr 24, 2016 | 06:56 AM
Gunkata's Avatar
Gunkata
thank you. sorry for the n00b question(s).
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
