Wheel spacer suggestion...
on
I hope this is the right forum for this question, but I want to widen that rear stance a little bit, while still using the original studs. What size should I go with? I did some searching, but couldn't really find answers seeing as how "spacer" returns a bunch of other results.
25mm has enough clearance to use a slip-on spacer without having to remove the original studs. That size of a spacer will bring the tires out flush with the fender. I recommend doing the front wheels also if you're going to add spacers to the rear.
Anything else.... is just retarded.
04-04-2016 07:52 AM
